Previous in Forum: M25 concrete   Next in Forum: Bending Moment of a Cylindrical Tower
8 comments
Stone Piles
08/26/2010 7:40 AM
what is the concept of gravel piles?
Pathfinder Tags: gravel piles
Re: Stone Piles
08/26/2010 9:27 AM
My uncle had regular piles... Gravel piles sound VERY uncomfortable.
Re: Stone Piles
08/26/2010 10:00 AM
A grouping of small stones whose maximum elevation is significantly above the surrounding terrain?
Good Answers: 146
Re: Stone Piles
08/26/2010 7:03 PM
Habitat for shrews.
incus opella
Good Answers: 19
Re: Stone Piles
08/27/2010 3:02 AM
google "gravel piles" and you will get your response which will be far more enlightening than any responses you can get here.
malgré cela: gravel piles go down to a lower stronger layer of load bearing material - very much like normal piles
omw7
Good Answers: 60
Re: Stone Piles
08/27/2010 7:23 AM
Re: Stone Piles
08/27/2010 10:32 AM
Much better! Thanks again.
Re: Stone Piles
08/28/2010 1:20 AM
Gentlemen,
Gravel or Stone Piles are basically used to improve the load carrying capacity of ground to support heavy loads within tolerable limit of settlement. This is a ground improvement technique. Bores are made in the ground at calculated spacing and depth and gravels are filled in the bore holes under vibration.
Akhtar Naviwala
Bechtel
Saudi Arabia
Re: Stone Piles
07/26/2024 6:57 AM
Register to Reply 8 comments
akhtarnavi (1); artsmith (1); Doorman (1); kramarat (1); lyn (1); omw7 (1); peterg7lyq (1); PWSlack (1)
You might be interested in: Stone Blocks and Slabs, Stackers and Reclaimers
