Previous in Forum: Stone Piles   Next in Forum: Plasticity Index
Bending Moment of a Cylindrical Tower
08/29/2010 8:14 AM
I have to calculate the bending moment of a hollow cylinder of mass m, resting on 4 legs. height of each leg is 3mts and height of cylinder is 4mts. The force acting on the tower is due to the wind load. So how do i calculate the bending moment caused by the wind on the cylindrical tower??
Re: Bending moment of a cylindrical tower
08/29/2010 9:52 AM
Why do you have to calculate this ! Why not somebody with the skillz required ?
Re: Bending Moment of a Cylindrical Tower
08/31/2010 12:02 AM
Reference values for intensity of wind pressure in Newton per square meter under light conditions is 1270, under medium conditions 1910, under heavy conditions 2550; for a height upto 30 meters.
Knowledge sharing is a WIN-WIN situation
Good Answers: 74
08/31/2010 12:06 AM
The bending moment is F*d where F is the wind force on the cylinder and d is the vertical distance from the centroid of the force to the point where you wish to find the moment.
Design of the support structure is a specialized job which requires the services of someone familiar with structural principles. Please do not try it on your own.
Bruce
08/31/2010 9:07 AM
Thank you.
Also, does the weight of the cylinder affect the bending moment? if yes, how?
I mean does the static load( i.e mass of cylinder) will have any affect on the bending moment?
Good Answers: 74
08/31/2010 12:51 PM
The weight of the cylinder does not affect the bending moment (or overturning moment, MOT) but it does help to resist it. If W is the weight of the cylinder, T is the tension in one of the two windward legs and x is the center to center distance between legs , the resisting moment MR is:
MR = W*x/2 + 2T*x
To prevent overturning, MR must exceed MOT by a safety factor (usually 2.0) so:
MR = 2*MOT.
Bruce
Good Answers: 74
08/31/2010 1:49 PM
Let me modify my earlier answer.
The weight of the cylinder does affect the net moment. The net moment is F*d - W*x/2. This is the moment applied at the base of the four legs as a result of wind and dead load combined.
Bruce
Anonymous Poster (2); ba/ael (3); mountk2 (1); peterg7lyq (1)
