Previous in Forum: Commercial HVAC Cooling Coil Performance Issue   Next in Forum: Anti-syphon hole
Stud Bolts & 2 Nuts
08/26/2010 12:43 PM
Hi,i'm looking for the table standard to choice the stud bolt&2nuts for the flanges whit this profile:
SIZE PN BOLTS DIAMETER , LENGTH OF STUD BOLTS
DN25 10/16/40 M?/M?/M? FOR EXAMPLE 110MM?
DN40 10/16/40 M?/M?/M? ?
DN50 10/16/40 M?/M?/M? ?
DN65 10/16/40 M?/M?/M? ?
DN80 10/16/40 M?/M?/M? ?
DN100 10/16/40 M?/M?/M? ?
DN125 10/16/40 M?/M?/M? ?
DN150 10/16/40 M?/M?/M? ?
DN200 10/16/40 M?/M?/M? ?
ALL OF FLANGES ARE WELD NECK AND THE THICKNESS GASKETS ARE 5MM
Re: Stud Bolts & 2 Nuts
08/27/2010 7:55 AM
Try Kempe's Engineers' Yearbook, any edition.
08/27/2010 9:25 AM
thank, but it's not possible for me to find the book,is there any table on one or two pages?
Good Answers: 38
08/28/2010 8:58 AM
Gape.....
Here we go again...!!
Not enough information....what is the pressure class of the flanges ??/
Class 150 ?.....300?
Have you tried a GOOGLE search........or do you want someone to do that for you ?
08/29/2010 12:43 PM
Hi,but I told the class of flanges,pn16 means the pressure nominal of flanges is16bar on din standard.
pn20=class 150 on ansi standard and pn50=class300 and...
08/31/2010 4:36 AM
Hi, you can refer ASME B16.5 for similar things.
duongtrung84 (1); gapee (2); MJCronin (1); PWSlack (1)
You might be interested in: Bolts, Pipe Flanges, Timing Pulley Flanges
