Previous in Forum: Bladeless (Coanda) Fan   Next in Forum: Cannot Get Replies
9 comments
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member
Recip Compressor Shutting Down Loaded
08/26/2010 5:42 PM
I am working with a new compressor installation with a pair of reciprocating compressors operating in parallel that share a processing unit between two stages of compression. For various reasons, an individual compressor shutting down can cause the machine to shut down in a loaded condition. Every recip compressor I have worked around (admittedly slow speed machines) has always unloaded or had the recycle valve open to the suction on shut down but I haven't ever been able to find out why. My intuition is that once the driver is de-energized, the compressor still doing work will act as a large brake and the machine will come to a stop quickly and that this sudden change would be unhealthy but I don't really know that. When I asked, the answer was that it isn't recommended to shut down a recip loaded but that it shouldn't hurt. Can anyone provide a more fleshed out reasoning for this?
Money doesn't talk, it screams in your face.
Re: Recip Compressor Shutting Down Loaded
08/26/2010 10:01 PM
I am unclear whether this is two compressors in parallel or in series, as the wording "two stages" seems to imply.
I don't think the loaded shutdown would be harmful other than some roughness in pressure control. This would happen on power failure, for instance. On start or restart, the controls should ensure the compressors are unloaded. If this is a two-stage package, the high stage should start first, reducing the intermediate pressure to avoid stalling the low-stage compressor.
08/26/2010 10:54 PM
Sorry for the confusion, it is indeed two separate, multiple stage machines in parallel. Yes, on restart, the machines will be unloaded for sure.
Good Answers: 27
08/27/2010 5:59 AM
As you have said, it is fairly common practice to unload recips before stopping. However, I cannot think of any adverse effect on the compressor if it is shut down loaded. It will decelerate much more rapidly than if unloaded and may put some braking load on the coupling and driver, but I cannot imagine that this would pose too much of a problem.
I have no special talent. I am only passionately curious. Albert E
08/28/2010 12:46 AM
On all of the reciprocating compressor units I've worked on (Refineries), the emergency shutdown (trip) will kill power to the driver while simultaneously load the compressor to 100%. Reasoning is that under emergency (trip) conditions the compressor must come to a full stop to prevent injury or (further) damage (loss of oil pressure, low suction pressure, high discharge pressure, high vibration or extreme rod drop readings). In case of a normal (programmed) stop condition, the logic controller will usually follow the reverse of the startup loading sequence; e.g. Unload to 0% in a programmed time frame or steps, then stop the driver followed by a post-lubrication cooldown period. I hope this helps you.
Good Answers: 67
08/28/2010 8:25 AM
Stopping suddenly under full load in some situations like power failure etc is nothing abnormal for the compressor. In fact, it is taken care while designing by OEM. Please get your doubt clarified by them. You have not indicated the working fluid.
08/29/2010 5:43 PM
Look for faulty unloading mechanism/ solenoid or even relay signalling impending (normal) shut down.
08/30/2010 8:06 AM
Thanks everyone for the responses, it seems to be that you would normally program the machine to unload and then stop but there are some scenarios (such as the E-stop that one poster mentioned) where it may not happen.
08/31/2010 6:58 AM
I have worked with 2-stage refrigeration compressors for many years (some paired in parallel and others single use) and note that no one has mentioned the risk of compressor damage when starting under full load. I believe there is a risk of bending a connecting rod or stalling/overloading the motor. This is most likely if liquid refrigerant gets back to the compressor but I think it is also possible if handling huge volumes of gas through valves that generally handle much lower volumes. It will all depend on the situation and the compressor. The safety cut-outs etcetera try to prevent this but there is the odd time when they will turn out to be inadequate.
The usual time that we have to start under full load is after having to turn off the power for some time, so that the pressure equalises around the system and these days you cannot just vent off some pressure to atmosphere just because there is no frig. engineer handy! Normally we do get away with a start under equalised pressures but we always watch like hawks for the protection devices to work properly and no nasty noises to happen.
Hope it's useful.
Good Answers: 67
08/31/2010 7:18 AM
I think the poster has no such problem which you have encountered perticularly for 2-stage refrigeration compressors. He has not even specified the medium. Please check whether your evaporator is above the compressor which is route cause for liquid entry in to compressor. Starting with load is certainly to be avoided. But stopping with load will not cause any adverse impact on the machine.
Register to Reply 9 comments
betomachine (2); Kaisan (1); pritam (2); Ptrend (1); rdoest (1); Tornado (1); wheel (1)
