Previous in Forum: Heat Reflective Fabric/Material   Next in Forum: Adsorbed Synthesis Gas
Pramod Sinah
08/28/2010 2:12 PM
still i am having cnfusion regarding reactivity of coke
what will happen if we use a coke of reactivity 23 insted of 21
Re: pramod sinha
08/28/2010 2:19 PM
don't you have a chart?
Re: Pramod Sinah
08/28/2010 2:58 PM
I found this in about 10 seconds:http://www.chinacoke.com/reactivity.cfm
Good Answers: 243
Re: Pramod Sinah
08/29/2010 2:21 PM
This is a classic economic problem. in my opinion, if you actually control the blend of high quality coals, and manage the coking process, this is a non issue.
Its an expensive test and it gives you non useable results- ie, "Oh My, I have a 23 reactivity not a 21, what should I do?"
My guess is you aren't going to decrease wind or burden rate. Nor are you likely to alter the make up of oxygen, cO2, or lower the raceway temperature so...
And my guess is they aren't going to fire the supplier, so ... so just what should be done?
My dad took his own blood pressure 10 times a day at home.
What did we do with that data?
Nothing.
Determine the spec you need. Test coke for compliance. Reject material that fails to comply.
But if you are in a position where you have to take it, well, Swallow hard and take it.
Just because you can test something doesn't mean that the results will help you, or be actionable.
If you understand what this test implies about the product, then you should speak to the supplier and adjust the blend and process. But don' expect the price to stay the same.
Economics!
Milo
Re: Pramod Sinah
08/29/2010 5:35 PM
Hi Milo,
Nice answer! I wonder though, what percentage of "Guest" actually find their way back to the thread they started, since they don't get any email when an answer is given.
Would knowing that make our responses any different? Probably not.
Mike
Good Answers: 243
Re: Pramod Sinah
08/29/2010 11:00 PM
Thanks Neighbor.
I would say that I get closure from guests no more than a third of the time, but I haven't really tracked it.
It is frustrating to see folks get test results that they don't understand, and wonder about how management thinks that they are saving money with such an arrangement.
This is actually a purchasing problem, if the spec limit is violated.
But non actionable data is a real aggravation for me.
If you don't know what to do with the test results, don't test.
If you can't do anything because of the results, why test? Why worry?
Powerlessness sucks.
But its not an engineering problem.
Thanks for the positive comment.
Milo
lyn (1); Mikerho (2); Milo (2)
