98 Cavalier z24 with 180,000 miles. I have had this car for 9 years and experience intermittent rpm accelerations at all speeds. The RPM's will flutter at a consistent speed from 2-5, if you press the accelerator it will run normal. This car will act up and for days and then will run great for months. Most of the time it will not give any codes. The engine light does not usual come on- once in a while the ABS light will come on when we have this problem. We have changed the catalytic converter, coil pack (x4) , 02 sensors. I have seen some other post the lead me to believe it may be my ECM.
