Previous in Forum: Shutdown Valve & PST   Next in Forum: Stroke Testing a Process Control Valve
Earthing DC Point
08/29/2010 2:53 AM
1)In a control panel For DC voltage ( 24 VDC) where should Neagtive be connected,should it be connected to Safety Earth Or Instrument Earth .
2) Also how we calculate the size of Safety Earth wire ( From Panel to ground bar)
Regards
Jose
Re: Earthing DC point
08/29/2010 8:00 AM
1. Instrument earth. Safety earth is just that, in the event the box get charged it has a path to ground and trips the breaker.
2. The maximum current of the supply will dictate the earth wire gauge to the ground bar.
aerospaced
08/29/2010 8:22 AM
3. Also the length of the earth wire, it's material construction & it's route (I.E. in the ground, through conduit or strapped to cable tray) will determin its gauge, in an ideal situation you should keep the distance from earthing ground bar to panel as short as possible & make sure you have good clean & tight connections.
08/29/2010 8:26 AM
1) Please do not get distracted with the terminology, you have to connect the negative wire strictly in accordance with the wiring diagram provided by the equipment manufacturer, dedicated terminal block and respective terminal number are there in the diagram as well as in the equipment manual.
2) As a safe consideration take fault duration to be one second, accordingly minimum crossectional area of conductor in mm square can be obtained by dividing system fault current with 214 in case of copper conductor or 160 in case of alluminium conductor.
Knowledge sharing is a WIN-WIN situation
08/29/2010 8:40 AM
as per NEC
ground wire size is dictated according to amp draw on either the load or service
Re: Earthing DC Point
08/31/2010 3:41 AM
<...2) Also how we calculate the size of Safety Earth wire ( From Panel to ground bar)...>
One uses British Standard 7671.
Aerospaced (1); aerotech (1); Anonymous Poster (1); mountk2 (1); PWSlack (1)
You might be interested in: DC-DC Converter Chips, AC-DC Adapters
