Previous in Forum: Cannot Find Alternator's Suppliers/Manufacturers   Next in Forum: Certified Lifting Equipment
Pump Discharge Pressure Problem
08/30/2010 6:10 AM
A pump & turbine which were suppose to send oil to a centrifugal steam compressor frequently has a problem of gradual drop in discharge pressure even after repairs. What could be responsible for this problem?
Good Answers: 27
Re: pump discharge pressure problem
08/30/2010 7:32 AM
Gradual drop in discharge pressure of a centrifugal pump:
  • drop in rpm
  • drop in suction pressure (level in suction vessel)
  • increase in internal clearances
  • increase in roughness of wetted surfaces
  • decrease in diameter of impeller vanes
  • reduction in piping resistance of the downstream system (opening of control valve, leaking relief valve etc)
Sure there are more but that is a start.
I have no special talent. I am only passionately curious. Albert E
United States - Member - American all the way Hobbies - Target Shooting - Aint nuthin like killing an innocent soup can!!!
Re: Pump Discharge Pressure Problem
08/30/2010 9:52 AM
Could also be the wrong oil in the system.
As the viscosity changes, the pressure drops.
I would check this first as it could be a VERY easy fix.
Give me enough duct tape and I can fix anything!
08/30/2010 10:06 PM
what repairs? pump losing pressure..... questions we need to consider * speed constant * filters/strainers clean * oil viscosity * temperature discharge is dropping is the suction steady? -have you already addressed these points?
klearzen
farmatt (1); Kaisan (1); klearzen (1)
