Previous in Forum: Modifying A Hand Operated Globe Valve To Be Remotely Controlled   Next in Forum: Solar Hot Water Panel Efficiency
Chemical Ratio Tester
08/31/2010 11:25 AM
Hi all,
Does anyone know if there is a chemical ratio tester?
For example, If I make a chemical tank, HF - HNO3 - Di, after 1 week, I want to check what is the ratio of the chemical? Does anyone know where can I buy the equipment?
Re: Chemical Ratio Tester
08/31/2010 11:34 AM
For a mix of hydrofluoric and nitric acids, after one week the tank will be gone, as will the contents - unless the tank is made of something like borosilicate glass. Beware the exotherms in the drainage system!
Check-out the Cole-Palmer chemical resistance database on the 'net. Choose an "excellent"-rated material-of-construction for the tank, and the ratio of materials in the tank after one week will be the same as it was seven days ago, other influences ignored, thereby obviating the need for such an instrument, the like of which does not exist at present.
08/31/2010 3:21 PM
Not even borosilicate glass:
http://www.pegasus-glass.com/pyrex.asp
Register to Reply 2 comments
