Previous in Forum: Vortex Tube   Next in Forum: Weight Calculation Formulas For Beam, Angle, Channel, Sheets.
Petrolatum Coating
09/01/2010 1:36 AM
Hi.... Can anyone pls tell any specification regarding the coating to be applied(if any) on the flanges of two mating Ductile Iron and Cast Steel. In my site, the puddles are of CS and pipes are of DI. Hence, there are many places where the connection between puddle and the pipe is DI and CS. thanks
Re: Petrolatum coating
09/01/2010 2:52 AM
What is the fluid inside the pipe?
Is the pipe in air or is it buried?
09/01/2010 2:54 AM
turbid water
09/01/2010 2:57 AM
What is the intended use of the turbid water?
09/01/2010 12:53 PM
When we play '20 Questions', should the poster be charged both times when you have to ask the same question two times?
09/01/2010 3:52 PM
The poster should be awarded 1/2 point for directly answering 1/2 of the questions posed.
However, a 1/2 point penalty will be assessed for not answering 1/2 of the questions posed.
We are at Q#4.
Doorman (1); lyn (1); PRASOON (1); PWSlack (2)
You might be interested in: Coating Services, Coating and Spray Booths
