Previous in Forum: Fault Level   Next in Forum: Heat to Electricity Conversion in ACs ?
Forced Guide Contact Relays
09/01/2010 4:15 AM
hello everyone..
i want to ask about the function of these relay..
after i read an article about "relay" in wikipedia.. i confused about this sentence, especially i have underlined "The function of forced-guided contacts is to enable the safety circuit to check the status of the relay"
i hope all expert engineer and electricians willing to help
thanks,, regards
Re: forced guide contact relays
09/01/2010 4:26 AM
Force guided contact relays have sets of contacts linked mechanically so that if one set is open, another is closed. If one set of contacts (typically the contacts carrying power to some king of actuator) becomes welded, neither set changes state when the relay coil is energized or de-energized.
This means that in a safety-critical application, the state of the contacts mechanically linked to the power contacts can be monitored to verify that the relay is operating correctly.
Typically two such relays would be used in series with the load. There is a very small probability that the contacts in both would become welded at the same time, and by monitoring the state of the relays with the linked contacts, a failure of one relay can be detected (by e.g. a Safety relay or Safety PLC) and the system can be put in a safe state, with no operation possible until the failed relay has been repaired or replaced.
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
09/01/2010 4:53 AM
Your answer is complete and self-explanatory.'Forcibly guided contacts' refers to a safety system of contact configuration in which 'break' and 'make' contacts within the set are never closed at the same time.
nvmani
Good Answers: 164
09/01/2010 5:50 AM
GA.
Something like this from Rockwell?
09/01/2010 9:08 AM
Too good. You have explained the concept in a brilliant way.
nvmani
Good Answers: 164
09/01/2010 9:23 AM
Thanks ... but disclaimer...it is Rockwell who did that
JohnDG (1); kvsridhar (2); nvmani (2)
