Previous in Forum: ANSYS Tutorial for Getting Started   Next in Forum: Sizing a Water Service for Residential Home
M6 Bolt Size
09/01/2010 1:35 PM
when we say that hex. head bolt m6 X 15mm long. what does M6 mean?
david_james
Good Answers: 48
Re: M6 Bolt Size
09/01/2010 1:51 PM
M means metric and 6 means nominal 6mm diameter
Good Answers: 137
Re: M6 Bolt Size
09/02/2010 5:38 AM
Yes, the unthreaded part (if any) of the shank is 6mm diameter. The major diameter of the thread is a little less as the tops of the threads are rounded. M6 bolt head and nut are 10mm across flats.
Cheers........Codey
Good Answers: 48
Re: M6 Bolt Size
09/02/2010 6:40 AM
I thought that 6mm was actually the major diameter, but I could be wrong.
Good Answers: 137
Re: M6 Bolt Size
09/02/2010 9:32 AM
Hello Holzfeller
You might be right. The drawing I have shows dotted lines meeting at a theoretical point, but the actual thread form rounded off below that. Shows dimension H for thread depth between these theoretical points, so for M6, pitch 1 mm, H = 0.5/tan 30° = 0.866 mm. Distance from tip of rounded thread to the theoretical point = H/8 = 0.11 mm. I assumed the 6 mm is between the theoretical points, making actual diameter about 5.8 mm. But I could be wrong, it doesn't give distances from the bolt axis so can't tell from the drawing. I might measure one sometime!
Cheers.......Codey
Good Answers: 48
Re: M6 Bolt Size
09/02/2010 10:02 AM
Hello Codey,
Yes, some of these drawings are not so obvious & need careful reading. It just happens I was looking at M6 & M8 thread dimensions at the weekend, checking some screws for which I need to tap some holes. I'll re-measure them later.
Re: M6 Bolt Size
04/23/2025 7:22 AM
Why does the <...we say that...> if it doesn't know <...what...M6 mean[s]...>?
Register to Reply 6 comments
Codemaster (2); Holzfeller (3); PWSlack (1)
