Previous in Forum: Domestic Central Heating in North America - Hot/Warm Air Heating   Next in Forum: What is Magnetism?
12 comments
What Sensor Should be used to Make an Altimeter?
09/06/2010 3:02 AM
pressure sensor is used to make a altimeter.....can u specify which pressure sensor should be used
Re: sensor....
09/06/2010 3:57 AM
One that gives an accurate relationship between the altitude and the read-out.
Re: sensor....
09/07/2010 3:26 AM
hey thnx for the reply but what i need is the description of the model of the sensor......
Re: What Sensor Should be used to Make an Altimeter?
09/06/2010 1:24 PM
Let me Google that for you... http://lmgtfy.com/?q=altimeter+design
09/07/2010 3:32 AM
google was good thnx bt i want to make a altimeter without using microprocessor chips i want to make it simple...........
Good Answers: 137
09/07/2010 5:33 AM
How about an ordinary aneroid barometer? Change the scale to read metres altitude.
Cheers...........Codey
09/07/2010 6:45 AM
aneroid barometer is fine but i have already submitted proposal on altimeter so i can't do that.........
Good Answers: 137
09/07/2010 9:19 AM
How about an absolute pressure gauge, preferably scaled for vacuum? i.e. at sea level it reads zero (zero vacuum, zero altitude), figures rising as altitude increases.
You need to make your own scale to read altitude. E.g. when pressure = 0.1 bar, altitude ~ 850 m. Also scale is not linear after the first few 100 m - at 8 km pressure is practically zero.
Cheers.........Codey
09/17/2010 3:52 AM
come on yar......... ok then suggest me a topic i will specify that there must no use of microcontrollers.......a simple project.
Good Answers: 137
09/17/2010 7:00 AM
I'm not with you. What has that to do with my post #7? Are you still talking about an altimeter?
An absolute pressure gauge does not need a microcontroller.
09/07/2010 11:55 AM
"...i want to make a altimeter without using microprocessor chips i want to make it simple..."
"...but i have already submitted proposal on altimeter so i can't do that...."
With each comment, you tell us another bit or piece that places limits on the correct solution. anish, are there any more restrictions you can tell us about? (Only spend $20.00 USD, mass limit of 400 gram, must also operate as depth gauge)
Good Answers: 97
09/07/2010 1:41 PM
You will also need a trap to keep the bong water out of the sensor.
Good idea though, being able to tell how high you are.
CRTL-Z
Good Answers: 29
09/08/2010 3:53 PM
How about an empty balloon with a knot in the end anchored to the bottom of the bong. Pressure decreases with altitude, balloon expands, water rises, bong goes out! You're at cruising altitude.
Register to Reply 12 comments
anish (3); Anonymous Poster (1); Codemaster (3); Doorman (1); pantaz (1); PWSlack (1); RDGRNR (1); Unredundant (1)
