Previous in Forum: Differences Between Types of Oil   Next in Forum: Fire Sprinkler System
Spec Blind
03/08/2007 2:05 AM
My question is: What is the purpose of placing a spec blind in a control valve manifold? Are there considerations in using spec blinds?
Re: Spec Blind
03/08/2007 6:10 AM
"Spectacle blind", i.e. a piece of plate shaped a little like a figure-of-8 with one hole filled in? The presence or absence of the hole can indicate whether the connection is blanked or not.
Permit-to-Work systems usually require maintenance and construction activities on piping systems to be isolated from any source of potential danger; a closed and locked valve is usually insufficient to ensure safety.
Re: Spec Blind
03/08/2007 5:25 PM
"Permit-to-Work systems usually require maintenance and construction activities on piping systems to be isolated from any source of potential danger; a closed and locked valve is usually insufficient to ensure safety."
Many "Permit-to-Work" require each worker on the job to have his own personal "Safety Lockout-Lock" be locked to a group lockout device such as:
<http://www.graphicproducts.com/lockout/index.php>
Every lock on the device must be removed by the assignee before the equipment can be repressurized or in the case of electrical equipment renergized.
Re: Spec Blind
03/09/2007 7:42 AM
Spec Blinds were also created to serve as a quick visual verification that the equipment was either blanked off or operational. This permits a worker to quickly walk a line and verify that the equipment is indeed safe to enter and/or work on.
MechTech
Register to Reply 3 comments
mechtech (1); PWSlack (1); Stirling Stan (1)
