Previous in Forum: Spec Blind   Next in Forum: How Much Water is Needed to Rust a Hole in Steel?
Fire Sprinkler System
03/08/2007 4:34 AM
What should be the thickness of pipe used in fire sprinkler system .
Re: fire sprinkler system
03/08/2007 6:06 AM
It depends on the diameter of the pipe, the pressure it is required to contain and the temperature it is required to withstand.
03/08/2007 6:30 AM
...also the materials of construction of the pipe.
United States - Member - New Member Engineering Fields - Military Engineering - Member Engineering Fields - Mechanical Engineering - New Member
Re: Fire Sprinkler System
03/08/2007 3:11 PM
check with your local fire building codes, they should have the pressure rating for a sprinkler system.
