Previous in Forum: Conveyor System   Next in Forum: Earth Electrode - Safe Filling Compound
single phase motor winding
09/06/2010 3:03 PM
Dear friends i want to know
Hoe to check the single phase capacitor motor starting and running winding with out colour code or circuit details ?
Good Answers: 97
Re: single phase motor winding
09/06/2010 5:40 PM
The start or auxiliary winding is roughly twice the resistance in ohms, as the run winding. If that is what you are asking.
CRTL-Z
09/06/2010 9:13 PM
Not necessarily, because as I've commented, there are many types of such motors.........
Thanks.
Just live and .. Learn!!
Good Answers: 97
09/06/2010 9:51 PM
The dude asked how to check the start and run windings without colors.
Salami Salami Baloney.
CRTL-Z
09/07/2010 11:54 PM
Thank you
for your information Guru
regarding the resistance deference between starting and auxiliary winding.
09/06/2010 9:08 PM
Hi Nawas,
There're many kinds of single phase motors when referring to their accessories. E.g. a single phase motor with centrifugal switch, a single phase motor with a Running capacitor, a single phase motor with both of "a centrifugal switch & Starting capacitor", and a single phase motor with a combination of "a centrifugal switch , a Starting capacitor & Running capacitor", …. However, for the maintenance purposes, you have to check the motor accessories described above like the centrifugal switch , the capacitor(s) mounted on the motor surface,,also you have to check how good the motor bearings are if it has… if you do preventive maintenance on these accessories from time to time , you'll extend the life of such motors…
Hope this helps,,,,
Ramadan kareem,,,,
09/07/2010 11:57 PM
Thank your for your information Mr.Ali
Ramadan kareem
Nawas Khan
09/07/2010 2:20 AM
All process required max. 30 minutes. Remove the motor and take to a motor winding shop.
Register to Reply 7 comments
Ali18 (2); Anonymous Poster (1); nawas (2); Unredundant (2)
