Previous in Forum: Air Compressor Piping Problem   Next in Forum: Free Note Book Operating Systems - Are They Any Good?
Generator - Deutz E11.4 FM 2011
09/07/2010 3:20 AM
Hey! The generator that we always use is a deutz E11.4 F2M 2011. the problem is that, when it is running and the fuel level is on 100% but fuel spills out through where the floater is located. What does that mean?
1.Is it because the floater is faulty causing the genset to over load?
2.Is it because the timing of the solenoid is not appropriate?
3.Is there another problem causing this to happen?
Re: Generator
09/07/2010 4:18 AM
Any or all of these. What does Deutz have to say on the subject?
Re: Generator - Deutz E11.4 FM 2011
09/07/2010 7:44 AM
If it is running properly, the only problem you have is a faulty gasket on the carburetor bowl, or whatever houses the float, replace that and you should be fine.
09/07/2010 9:06 AM
I'm not sure about the ratios with Deutz, but most diesels only burn about 1/3 of the fuel that flows to the engine the other is used to cool and lubricate the fuel system, 2/3 s is returned, If the tank isn't big enough the temperature will rise causing the fuel to expand, or agitaion of the fuel or the location of the fuel return.
kramarat (1); norton850 (1); PWSlack (1)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
