We connected our 5 H.P. compressor to the 3/4" distribution line feeding air into a water well, to pump into the storage tank. After break-over, pressure runs at about 30 PSI. It is in operation many hours a day, 2-4 hours at a stretch, as we operate a plant nursery. We used 1/2" x 3' hydraulic hose to prevent vibration breakage, only to find it (after 2 months in service) very stiff, and actually leaking, from the heat is my guess. Bubbling appears on its surface. What gives, we tho't it would be the ideal answer! Aside from hard piping, are there better choices? Thanks.
