Previous in Forum: Hydraulic Cylinder Calculation   Next in Forum: Water Treatment
Horizontal Diesel Storage Tank (Saddle supported)
09/08/2010 11:24 PM
Hi!
Please can any one help me to get the preliminary drawing of the 20m3 Atp Horizontal Diesel Storage Tank (Saddle supported).
I need to give inputs to Civil for Piling, and they are requesting me to give the saddle support location.
Constrain is that i cannot increase diameter of tank more than 2.2m.
I have considered T/T 5300 & Dia 2200 mm.
Earliest reply on this would be highly appreciated....
Re: Horizontal Diesel Storage Tank (Saddle supported)
09/08/2010 11:37 PM
Why don't you get with "Civil" and have them ask their questions now, too?
09/09/2010 12:48 AM
Locate the saddles at 20-25% and 75-80% along the length of the tank, and submit a drawing to Civil for locating concrete supports.
Good Answers: 61
09/09/2010 5:31 PM
Here is what I used for early planning of Vessel Nozzle Orientation.
The optimum location for location was two "Zones" at each end of the Vessel.
These "Zones" were located back from each Tangent Line.
The zones were calculated as follows: "D" over (divided by) 4 and "L" over (divided by) 5
"D" is the Diameter of the vessel. "L" is the distance between the two Tangent Lines.
Your "D" over 4 = 550mm (in from each tangent line) Mark a line.
Your "L" over 5 = 1060mm (in from each Tangent line) Mark a line.
The "Optimum Zone" for your Saddles is in the 510mm area between these two lines.
Do it once and do it right
Good Answers: 61
09/10/2010 7:07 PM
The second line in the above posting should read as follows:
"The optimum location for the saddles is two "Zones" at each end of the Vessel."
09/23/2010 3:15 AM
can u help
for a tank, numbers of saddles how to calculate?
Good Answers: 61
09/23/2010 1:19 PM
Two only, one at each end.
Register to Reply 6 comments
lyn (1); nijocj2002 (1); PennPiper (3); Tornado (1)
