Ok' this is the question. How do I weld ASTM-A240 Type 304L stainless to A572 Gr 50 with a 1/4" fillet weld? What filler metal to use. I'm wanting to use GMAW or FCAW .045 or around there. Some of the welds will be rather long so going to use a "buggo". 572 base metal will vary in thickness from 1/2" to 1". And stainless will be a 3x1/4" flat bar layed flat with fillet on all sides.This will be a mount for a seal sandwiched between the stainless.so the overall idea is this, 572 base, stainless FB(with holes drilled and tapped dow the length), a ruber seal, then another stainless FB to sandwich seal with ss bolts. I am also concerned about heat input and distortion. Can anyone help me?
I hope I gave enough information to help (by the looks of it too much). thank you for any advice or experience you can share.
