Previous in Forum: Dosimeter Charger   Next in Forum: Temperature Indicator -urgent
19 comments
Type of Valve
09/10/2010 11:52 AM
Can someone identify this type of valve. See attached photo
Good Answers: 299
Re: Type of Valve
09/10/2010 11:59 AM
I will take a guess (a WAG):
Triple Offset Torque Seated (TOTS) Butterfly Valve.
Lots of guys will know for sure. I'm right or I'm wrong. Let's see.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
Re: Type of Valve
09/10/2010 12:29 PM
Sounds good... very technical... I'll buy that answer for a nickel!!
The only thing I might add is that on the right hand side, it resembles a pneumatic actuator. As for the left side... who knows?
Sometimes my thoughts are in a degree of order so high even I don't get it...
Re: Type of Valve
09/10/2010 12:42 PM
I would agree with chaotic, it looks like a remote operated butterfly valve. The heavy duty casing makes me think it is explosion proof and suitable for use in enclosed areas. Explosion proof merely means if it shorts out itself, it will not ignite an explosion if fuel vapors are present.
Drew
Re: Type of Valve
09/12/2010 7:24 AM
No, it's not EEx d. If it were, then the nuts holding the cover down wouldn't be removable with an open-ended spanner. A ring spanner or a socket set would be needed.
It might not even have any electrics in it.
Re: Type of Valve
09/10/2010 11:46 PM
Let me be more specific.
this valve is on a 6" line going into a Test Separator. Over the years it was sand blasted and painted so many times that there are no markings on it at all. It is pneumatically operated with spring return
Good Answers: 38
Re: Type of Valve
09/10/2010 12:46 PM
I'm tempted to say the part on the left side of the valve is a spring return assembly.
Venezuela - Member - New Member
Re: Type of Valve
09/10/2010 2:03 PM
Guys,
Maybe I will be wrong but it looks as a ball valve single action spring return
Regards
JP
Instruments-guy-SAV
Good Answers: 38
Re: Type of Valve
09/10/2010 2:44 PM
Based on the size of the valve body I'd have to agree with you JP... ball valve with a single action pneumatic/spring return actuator.
I'm going to have to correct my earlier statement based on one manufacturer's literature. It appears the left side is the pneumatic side (I think the small line going in is the air), the right is the spring return.
see the following for what I'm referring to...
http://www.valve.co.za/pdf_2009/v_a_procontrol/v_a_procontrol_vp_series_pneumatic_scotch_yoke_actuators.pdf
Good Answers: 58
Re: Type of Valve
09/10/2010 2:42 PM
The area looks to be a marine product transfer dock.
I would venture a guess of an emergency return to close product transfer valve.
Either spring, hydraulic, or pneumatic (non-electric) return to close (failsafe) system.
Re: Type of Valve
09/10/2010 2:53 PM
It looks kinda small for a marine transfer header system, but too big for your average marina offloading header.
Upon closer inspection of the image, I see small pilot lines going to the left side of the image. But I don't see anything that makes me think it is a pressure controlled valve. I don't see any wires going to the casing on the left, but that doesn't mean they aren't there. The casing on the right doesn't look like any controller I have used before but there are no marks on the top where a manual handle would go so I don't think this valve is operated manually often (ever).
I think we need more pictures. If you want us to be more accurate with the type and manufacturer we will need pictures of the data-plate or at least manufacturer's marks, country of origin etc.
Drew
Good Answers: 38
Re: Type of Valve
09/10/2010 3:01 PM
Excellent point! I've seen this type of valve before on an ammonia transfer line (although not this large and hence my learning curve). Air pressure to open and should the emergency situations arise, electrical controls dump the air pressure and spring shuts.
Re: Type of Valve
09/11/2010 12:44 AM
There are no markings on this valve due to blasting and painting. I need to fit a DVC and associated hardware onto this valve with position switches so i am desperately trying to find the make/model etc
Re: Type of Valve
09/11/2010 4:17 AM
Photo is not sufficient to understand the valve as you didnt send the complete photo(other side photo)
It is a spring return butterfly type valve.its correct.
But it could be a shutdown valve also.Try to look that if there is any positioner with scale or not.If no then check that if there is any limit switch or not.Check that if pneumatic supply passes through the soleniod to the actuator.
Give me above mentioned information. then only i will tell you the type of valve.To fix the DVC above mentioned informaton is required.
Re: Type of Valve
09/11/2010 6:12 AM
Here is another photo. Spring return correct. Are you sure it is a butterfly valve? It is being used as an SDV, is this to code? The signal for the valve comes directly from the Master control panel pnuematics through a three way versa valve that has a high level switch acting as the pilot on the versa.
The DVC and position switches are being installed as part of a SIL system.
Thanks
Re: Type of Valve
09/11/2010 9:10 AM
get the clear picture of pneumatic assembly....is there any limit switch?
Re: Type of Valve
09/11/2010 9:25 AM
No limit switch. Pull to open versa valve at control panel with a quick exhaust at the valve.
Re: Type of Valve
09/11/2010 1:52 PM
its a emergency shutdown butterfly valve....as per ur detail.
spring return actuator with soleniod and quick opening exhaust.
how do you fix a DVC..its not serving position control at all..as per your description its not a control valve.DVC to be used for position control.
Re: Type of Valve
09/12/2010 1:20 PM
AMO,
Why you need install a DVC?
DVC <----- Will be it to use for PSTV?
Could you get the P&ID for that section, I´m not familiar with marine installation,
What mean SDV?
I´m thinking yet that is a ball valve, lol
Regards
JP
Instruments-guy-SAV
Re: Type of Valve
09/12/2010 7:36 AM
If it is part of an oil/gas installation, it is inconceivable that there is absolutely no documentation about the valve, either when it was installed, or commissioned, or last serviced.
  • Start with the area maintenance technicians and talk to them. Find out what they know. When was the last time the valve was stripped for servicing? What parts did they use and from where were they purchased, for example?
  • Dig into the original documentation for the facility and see what's there. The valve must have a tag number on the drawings, even if its label is no longer fitted. Check the P&IDs for the facility and refer to the original valve specifications for the facility.
  • Is it similar to other valves at the facility that do still have their maker's labels? What do those labels say? Once a supplier is found, send them the photographs and ask for advice. "Is this one of yours? If so, what do I do to <blah, blah, blah> to it?"
Register to Reply 19 comments
AMO (4); Anonymous Poster (3); ChaoticIntellect (4); Doorman (1); Drew K (2); Instruments-guy-SAV (2); KJK/USA (1); PWSlack (2)
