Previous in Forum: Source Needed for Glass Cordage   Next in Forum: Glass scratch removal abrasives
ASME B16.5 , Calculation / Formulae of Volume of Flanges
09/11/2010 7:32 AM
CONSIDERING, 0% TOLERANCE & DIMENSIONS OF ASME B16.5, CAN YOU PL. GET ME FORMULAE OF VOLUME OF EACH TYPE OF FLANGES ?
ALSO, WOULD LIKE TO KNOW THE % DIFFERECE IN MIN & MAX VOL. OF ALL TYPES OF FLANGES.
Re: ASME B16.5 , Calculation / Formulae of Volume of Flanges
09/11/2010 12:35 PM
It's just elementary geometry, consisting of adding and subtracting the volumes of various cylinders (V = pi r2h) and cones (V = pi r2h/3).
Or you could do it the Archimedes way: Put each into a graduated bucket of water and read off the liquid rise.
09/11/2010 2:49 PM
TRUE & thank you. Archimedes theory is possible if we have acess to graduated vessel and all the types / sizes / classes of flanges.
WNRF is like a cut cone , making it difficult to apply geometry rules.
I was/ am looking for some readymade tables / There is too much of work to do with respect to tolerance of variables in dimensions.
I tried summing up the sections of SORF & applied formulae in xls. In certain sozes, I found a great discrepancy in theoritical weight vs approx. weight. (SPG of 304 = 8.3, 316 = 7.99?)
If some has done this work, it is quite helpful.
09/11/2010 2:56 PM
Also, it is understood that VOLUME OF CUT CONE = vol. of imaginary full size cone -(minus) vol. of imaginary top of the cone which is absent.
So, geometrical approach is possible, but, there is too much of work. So, I sought for the help if some one has already done this exercise.
09/11/2010 6:02 PM
The best bet might be to find a catalogue that gives weights.
Good Answers: 29
09/13/2010 4:12 PM
Here's a calculator to get you started.
AKFLANGE (2); RDGRNR (1); Tornado (2)
