Previous in Forum: Black Vinyl Dye   Next in Forum: Magnets to Dehumidify Air Flow
Designer
09/11/2010 9:29 PM
What is the minimum angle at which dry frack sand will flow freely down an inclined chute of pipe. Any other specs would be welcome. Johnnie in Tx.
Re: designer
09/11/2010 10:13 PM
I would take some dry frack sand and a piece of pipe about 6' long. Pour the sand into the top, move the pipe until the sand flows freely, measure the angle, and badda bing, badda boom....you've got your answer.
Re: designer
09/12/2010 3:40 AM
Bravo, it's the only way you'll get a decent answer.
There are many variables which may effect the answer (pipe diameter being just one).
GA from the Cat.
Oh I'd also suggest doubling the angle anyway, for as we all know as engineers 'if it can go wrong, it will go wrong'. It just needs one sticky recalcitrant grain to mess the whole thing up, if he starts chatting to his buddies and they stop for a drink on the way down the shoot...
Re: designer
09/11/2010 10:49 PM
Why it is perfectly obvious, the minimum angle is 1.001569. But this is only true when the sand is in a vacuum and subjected to the gravitational field of at least a Jovian satellite.
On a more serious note, this will vary greatly with the smoothness of the incline chute, the initial velocity of the sand and what if any mechanical vibrations are applied to the chute. I would expect that the average grain size of the sand will also have some additional effect on the critical angle.
I do remember that getting sand to start to slide is one of the classic non-linear chaos analysis problems. A pile of sand, at rest on an incline has additional sand slowly added to to the apex of the pile until a slide starts to happen. Always once the slide happens, more sand than was added ultimately slides down the incline. However, how much sand must be added each time to start the slide will be different each and every time. My fuzzy memory tells me that an unexpected organization gets discovered when one does this experiment. After making hundreds of tests the experimenters found that instead of one single peak of a likely critical amount of mass required to start a slide there were multiple peaks that were likely to start a slide.
Re: designer
09/12/2010 12:27 AM
If it's wet, the angle of repose approaches 90°, as anyone knows who has built a sand castle on the beach.
Good Answers: 61
Re: designer
09/12/2010 8:10 AM
Pour some of your "Dry Frack" sand on to a table top. When it has stabilized measure the Angle of the pile. That is it.
Do it once and do it right
Re: Designer
09/12/2010 6:35 PM
Most references seem to suggest 32-34° as the angle of repose for dry sand.
Register to Reply 6 comments
kramarat (1); PennPiper (1); redfred (1); Tornado (2); user-deleted-1105 (1)
You might be interested in: Chutes, Bulk Handling Conveyors, Industrial Conveyors
