Previous in Forum: Designer   Next in Forum: GPS Locator
87 comments
Location: 20 miles north of Mt. Shasta California along I-5...aka , Yreka, California.
Magnets to Dehumidify Air Flow
09/12/2010 1:41 AM
Water is repelled from a magnet, so I would expect humidity to be repelled also. I would like to use this to reduce the humidity of air going into my swamp cooler so that the air coming from the swamp cooler will be colder. My cooler discharges 200 cubic feet of air per minuet. I measure humidity by comparing the temperature with a wet bulb and dry bulb thermometer. If the outside air is (wet bulb temperature) 77 F and the dry bulb temp is 81 F, then the humidity is 84%. Rather muggy. This goes into my swamp cooler which increases the humidity to 91% to chill the air to 75 F (dry and 73 F wet). This is barely tolerable and excessively wet. A compressor air conditioner is unavailable due to electrical power limits. So this leaves the question about using magnets to reduce humidity.
This looks like a nice little project to set up and do on a kitchen table top. Lets see what you come up with.
Re: Magnets to dehumidify air flow
09/12/2010 3:33 AM
"Water is repelled from a magnet"
What have you been smoking?
09/12/2010 3:43 AM
No, no no... It's common sense which is repelled by a magnet.
09/12/2010 3:50 AM
His tin foil hat is magnetic?
Just think of the perpetual motion implications. Water in front, magnets in back, car goes forward. Move water to back, car stops.
Damned if I know what would happen in the rain.
09/12/2010 4:05 AM
Maybe that's why hovercraft have magnets in the hem of their skirts.
Good Answers: 204
09/12/2010 11:24 PM
all you need is a pair of rapidly rotating mirrors to split the magnetic force into negative energy.
09/13/2010 9:07 PM
All you need is a nice strong magnet and a kitchen sink to see the effects of a magnet held near a trickle of water. In my experience, water is repelled from a magnet held near a little stream of water falling from a faucet.
"Negative energy"....That would be a mass less void, without a detectable presence and presenting no appearance of existence. Useful for driving horses wild.
Good Answers: 130
09/14/2010 12:01 AM
I wonder if you put a meter across the stream, you might find a leakage voltage?
10/03/2010 12:14 AM
in earlier days someone has tried to generate electricity using earth's magnetism as magnetic poles and river thames as conductor and didn't find any appreciable voltage
pnaban
09/14/2010 1:35 PM
So if you flip the magnet over so the poles are opposite you attract water?
Good Answers: 243
09/14/2010 1:37 PM
Actually, try it with just your finger...
Milo
Good Answers: 204
09/13/2010 1:33 AM
you CAN use magnets to dehumidify... just freeze them first!
09/13/2010 9:12 PM
I tried that but noticed magnets do not collect frost as much as a near equal mass in the same environment that is not a magnet. I'll take pictures.
09/13/2010 8:52 PM
Ok, Magnets repel water. Clear enough?
09/13/2010 9:27 PM
Please show me an example of any magnet available to the average homeowner (NOT superconducting, unless you can sell me a verified room-temperature superconducting magnet for under $1000), repelling water.
A fine stream of falling water will easily be deflected (always attracted, if I recall correctly), by a rather small static electric field, so the repulsion should be fairly easy to show. If the stream is not broken into droplets, it would be possible to send an electric current through the stream, and that current would be deflected, but it would be a deflection perpendicular to the magnetic field, not an attraction nor a repulsion.
I DID try it in my kitchen with a hard drive magnet today! I could observe NO deflection. I HAVE observed (and demonstrated to classes) static attraction of water dozens, if not hundreds, of times.
09/13/2010 9:53 PM
Me too. The magnets in a hard drive are strong, but they don't demo water changes like those with one pole of the magnet on one side of the magnet and the opposit on the back side of the magnet. jkmagnetics.com and other suppliers sell lots of inexpensive powerful magnets on the cheap. I have some that will produce a 1/4 inch depression in a pool of water when placed in the bottom of a glass bowl with water over the top. I haven't tried this with mercury yet but I think it will make a better photo-demo of diamagnetics.
also see:utube search "Magnets and Water"
http://www.youtube.com/watch?v=2FvWtEdY4sE
Good Answers: 130
09/14/2010 12:08 AM
Is this distilled water? or tap water (town or well) or 'de-ionized' water commonly sold as 'battery water'?
Just asking as atmospheric water could be more like distilled water than the others.
09/14/2010 1:31 PM
Distilled water.
09/14/2010 2:11 PM
If that is a 1/4 inch diameter depression a fraction to a few wavelengths of light deep, then it's no big deal. If that is a depression of any diameter and 1/4 inch deep, then I gotta see it!
Mercury may or may not make an effect more obvious, but its an atom, not a bipolar molecule, so it would have nothing to do with water's supposed magnetic properties. About the only thing that water and mercury have in common is that they are liquids at room temperature!
09/12/2010 6:59 AM
WALOOB.
Try switching to decaf.
Good Answers: 243
09/12/2010 8:33 AM
Pseudoscience.
http://www.chem1.com/CQ/magscams.html
Milo
09/12/2010 8:52 AM
Maybe you were thinking of static electricity, not magnetism:
http://www.youtube.com/watch?v=VhWQ-r1LYXY
09/13/2010 9:37 PM
No, It was more in the line of
which at utube is a search for "magnets and water"
09/13/2010 11:35 PM
I did view a couple of the youtube videos. I'm open-minded, but highly skeptical of the Aussi infomercial, especially when I see an apparatus that probably cost $10 to produce being sold for hundreds of dollars! Obviously I don't know all the details on what exactly is inside the device, but...
The reflection of the light in the ceiling is effectively a highly magnified view of the light position, so an extremely tiny force on the water would produce a visible effect. It did appear authentic - I'll try to reproduce the effect myself, soon. I have LOTS of magnets available...
09/12/2010 9:01 AM
it's all starting to make sense to me now
that's why we have water softeners
the softener takes the chemicals out that are aquired when the water is in the ground,mainly iron particles. And that's why magnets repell water.
ok, gotta get back to Willie Wonka and his oompa loompas
Stub
09/13/2010 9:25 PM
Good Answers: 266
Re: Magnets to Dehumidify Air Flow
09/12/2010 11:24 AM
Remind me not to drink the water in California.
09/12/2010 11:27 AM
(pssst. Don't drink the water in California...)
Good Answers: 114
09/12/2010 11:44 PM
[clears throat]
There's more to California than the the emerald triangle
09/13/2010 6:09 PM
Actually considering Yreka is basically Oregon, the question seems consistent.
09/12/2010 3:22 PM
As others have said this is incorrect and will not work.
Perhaps you would have better luck removing the excess moisture from the air using a baffle (or similar) system covered in sponges or paper towels. As the air (drawin in by the fan) hits the baffles on its way in and/or out of the swamp cooler some of the moisture will be absorbed, reducing the overall humidity of the outgoing air.
Somewhere to start anyway using easy-to-obtain household products, just be careful that the excess moisture doesn't end up in your fan electrics creating a potential electrocution hazard.
09/13/2010 1:24 AM
First, as several others have said (often in unkind words), water is NOT repelled (nor attracted) by a magnet. I just double-checked, in case something had changed: no effect whatsoever.
Second, I've never spent any time in Yreka, but I have driven through a number of times, usually in the summer, when the temperature was not too far from 81°F. Perhaps I've been lucky, but I have the impression (no measurements involved), that the humidity was WAY lower than 84%. I'm wondering whether you may be doing something wrong while measuring your wet and dry bulb temperatures.
Third: If your daytime temperature is in the low 80s, then your nighttime temperature is most likely in the 50s. Run your fan without water at night, close up during the day, and you should be able to keep the house or building cool pretty much all day. If not, then insulate!
09/13/2010 1:28 AM
first of all a swamp cooler will only work properly in a dry hot area like desert conditions ( low humidity) as the cooling effect is from the speed of evapoation by passing the air over a water soaked batt ,If the humdity is high this will cause less cooling and as you say raise the hmidity in your building ( remember you must exhaust the same amount of air as you bring in or your humdity will also rise ) the best way to keep your hmidity down is to get a dehumidifer that works by collecting the moisture from the air and letting you dump the collected water . If your humidity is the high in the outside ambient air then the swamp cooler will not work properly . Possibly you could use a small room or container that could handle a large dehumidifier pryer to the in take of your swamp cooler ? A Lot of work but it could be done ! Jerry
09/13/2010 2:33 AM
kindly provide just one example of water being repelled by a magnet.
09/13/2010 2:47 AM
The water molecule is a dipole- which means it has a north & south pole- this is how a microwave oven heats as a rotating magnetic field moves the water molecules, which movement causes heat thru friction as the other atoms & molecules present resistance.
09/13/2010 8:36 AM
In a microwave oven, it is not a rotating magnetic field that moves the water molecules.
It is the Varying Voltage field that moves the molecules. They will start to vibrate because of the Voltage field variation at the frequency being used in the microwave oven.
Please correct.
09/14/2010 3:45 AM
Hmmm- I think you are confusing the issue- obviously there is a varying electro-magnetic field- I simply stated the obvious magnetic effect on a water molecule with magnetic dipole - voltage variation?-in any microwave oven I have seen & worked on- no such thing!. If there was voltage variation- one would expect the output power to vary as against the input power as against the load as against the shield presented by the Faraday cage & measured simply at the cage interface with a radiation tester(obviously I am using a set power level!)- as in normal cooking- unless you are referring to sensor level cooking!. To educate yourself on microwave cooking may I suggest you use Wiki?- there is a comprehensive coverage.
09/14/2010 7:25 AM
I am not confused for any bit.
You can read all the WIKI you want but still do not understand the principle of Microwave cooking.
The microwave is an electromagnetic wave with a wave length in the micrometre range ... (Ghz ?).
The water molecule dipole does not have to be a magnetic dipole! it is an electric dipole. What makes the molecules to shake and vibrate to the extend that they will heat up is the Electric field variation more than anything else. And by the way, you do not need that high a frequency to heat water to steaming level. A frequency in the range of 30 MHz will do it if the voltage of the field is high enough. That is the radiated voltage reaching the water is high enough.
The voltage variation is in the emitted electromagnetic wave that is generated. You are not going to see a voltage variation in the input power supply! You have an oscillator circuit in the equipment that generates the high frequency electromagnetic wave which is then broadcasted into the oven cavity. The faraday cage of the oven is specifically to contain the electric field and prevent broadcasting the wave outside the enclosure.
What heats the water is the electric field variation acting on the water molecules and not the magnetic field variation.
09/14/2010 12:05 PM
You are correct in saying that the varying voltage is the microwave voltage itself - no magnetic rotation required.
But you've got the wavelength all wrong. From Wikipedia: "A microwave oven works by passing non-ionizing microwave radiation, usually at a frequency of 2.45 gigahertz (GHz)—a wavelength of 122 millimetres (4.80 in)—through the food."
I've known the 2.45GHz frequency since the early '60's, and λ=c/f=3.00E8(m/s)/2.45E9(1/s)=0.122m or 122mm, so the values give in Wikipedia are correct.
There do exist industrial microwave ovens that work at other frequencies/wavelengths, but I believe all home microwave ovens use the same frequency pf 2.45 GHz.
The only reason you can see inside most microwave ovens while they are operating is that the holes in the perforated metal door panel are very small compared to the wavelength, so virtually no microwave energy can pass through the holes. If microwaves had wavelengths in the micrometer range, they would pass through those holes and damage people and other things outside the oven.
09/14/2010 1:44 PM
Thanks for the details on the wave length of microwave ovens. I did not check the frequency or the wave length they worked on. I simply detailed the theory behind the heating of the water by the electromagnetic wave energy.
thanks
09/15/2010 3:08 AM
Thank you for your input-are you saying that the north & south poles in water molecules are non magnetic to magnetic attraction as we know it, but are attractive to electric fields?-only?- if true this has vast implications for the world, universe, & almost everything. Now you are also saying that the microwaves(almost 5"!) vary in electric fields?. you have said that the oscillator varies the voltage- well the wave length is set - the frequency is set- are you saying that the wavelength of almost 5" somehow turns the molecule of water which is truly miniscule?- oh well - if all else fails- can always turn to theory- or are you saying that every oscillation has to start from 0 to reach max then repeats & this is what you call voltage variation?. How the f====hell would anybody measure this?- unless thru results- or an extremely fast cro!. Cheers from someone who really wants to know!.
Good Answers: 130
09/15/2010 3:24 AM
09/15/2010 7:17 AM
Well, maybe you should have a look at the reply #58 on this topic(forum). Click on the link and read! You will have your answer for how to measure electromagnetic waves frequency etc.
Before starting to rant and deduct conclusions on an issue you seem to be ignorant about, and using words like f.... invoking Hell... think and learn by doing some research!
I can't see why you got so excited about something you need to go back to school and refresh: Electromagnetic waves and Oscillations are dealt with as of that level somwhere..(?). Yes, The voltage is varying up and down as you said from 0 to a max and then back to 0 (and depending on how much you know...) to - the max reach before (Look at a sinusoid shape wave that you should have been familiar with in you 2ndary school ...), the voltage varies in time... the current also... and this generates a magnetic field at right angle to the propagation direction of the electromagnetic wave...
Nevertheless, Even if the water molecules have some affinity to a magnetic field, it seems to be very very very weak and maybe indiscernible for us common humans (Maybe some very advanced laboratory equipment could detect the influence, but I do not have any reference (reputable, that is) for such ...). But Electric Fields (Voltage fields), have been found to exercise influence on the water molecules. The best proof is the microwave ovens where you can heat a glass of water to prove it. Even if the microwave has a magnetic component, magnetic fields by themselves have not been found to attract water or to polarise the water molecules etc.
By the way, you make vast conclusions about the influence on the Universe if water was not attracted by a magnetic field! On What do you base your deduction if you do not even know how an electromagnetic wave is made or works or anything related for that matter?
Good Answers: 130
In reply to #59
09/15/2010 9:24 AM
I can't see why you got so excited either. He said he really wanted to know, so I told him. Nuff said, "point/s made", I would have thought.
In reply to #60
09/15/2010 9:35 AM
Maybe you are right.
Good Answers: 69
09/16/2010 9:54 AM
You are correct, but I can't find any evidence of a material capable of shielding an electric field, as opposed to electro-magnetic waves, wich can relatively easy be shielded.
Yahlasit
In reply to #65
09/16/2010 12:43 PM
The faraday cage was mentioned before and that is why I kept to it. In a sense, the grid in front of the oven window bounces back the EM waves because of their small apertures in relation to the wave length used.
You are correct, the electric field by itself will be felt across if applied as a voltage field. But then we are talking about electromagnetic waves...
09/13/2010 7:54 AM
Swamp coolers only work in very dry climates. Up where you live, where the evenings are fairly cool, I think you could lose the swamp cooler and just install a dehumidifier. Combined with a few ceiling fans, you should be fine.
I'm not gonna touch the magnets repelling water statement.
09/13/2010 5:49 PM
It seems that water has some magnetic dipolar properties. I once read about those dipoles and the snow flakes shapes. Anyways, here is a link: magnetic water
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
Good Answers: 243
09/13/2010 6:07 PM
NO critical thinking in that link.
Milo
09/14/2010 10:33 AM
Far from me to start a controversy, I did some magnetics research for switching power supplies, and I can accept that water can be paramagnetic. How much? Idonnow! But those guys who publish an article in Nature have done some experiments and, if you pay, you can read the whole article. Here is the abstract: abstract
What good came out of it? Idonnow!
Is it good to drink this kind of water for my prostate? Idonnow!
So why am I throwing those links?.....R..r...Idonnow!
Good Answers: 243
09/14/2010 11:00 AM
My dear colleague dr idonnow,
One of the great tools of obfuscation is to overwhelm the reader with a veritable plethora of references, and then either the reader is overwhelmed and says it must be true, or the reader tires of running down all the rabbit holes and gives up on trying to make sense.
Making a case is much more difficult.
Whenever i see a $h*t dump article with loads of claimed references, I ignore them on first scan and look for "claims" that I figure are "preposterous"- inconsistent woith what I already know, incoherent with what is claimed, incongruent with settled facts or my personal experience or education.
The statement "Also, when water is magnetically treated, more hydroxyl (OH-) ions are created to form alkaline molecules, and reduce acidity. Normal water has a pH level of about 7, whereas magnetized water tends to be more alkaline." gives me, a modestly achieving chemistry student, pause to reflect- How can there be more -OH ions in magnetically treated water? If mass is conserved, those pesky H+ ions must be lurking somewhere? And that somewhere must not be in the water if the water (presumably tested) tests abundance of -OH ions... and alkalinity increased...
So on this one single fact, I am able to establish that the author or editor is dealing in an alchemical form of pseudo chemistry where H+ ions can be magnetically teleported out of an aqueous solution leaving only negative ions (i call these -OH thingies mother in law ions by the way as in "Mother in law is coming? -OH ! )
The broadly unrefutable claims such as "water is returned to its healthy state" (Huh? )
Unattributed claims "There are reports of people resolving bladder problems" "reducing blood pressure" etc etc.
-all of these add to the case that this is BS. It wouldn't have passed my 5th grade teacher, let alone college rhetoric...
This material does not withstand a cursory critical reading, despite the pedigree of the Nature reference. Like any good conman, flashing one good "bill" while a bunch of non- money is backing it is all that is needed to convince the "mark."
When one finally decides to check out the pedigree of the author, And ask the ethicists' question " what is the object of the act?" all things are made clear.
The author is promoting her own Magnetic therapy company...
Debbie Shimadry
Debbie Shimadry is a qualified pain nurse specialist that has worked as a trained nurse in the N.H.S for 12 years. Due to chronic pain problems, she had to leave her job and trained as a Magnetic therapist. She is the director of leading magnetic therapy company world of magnets ltd.
Interests and Hobbies:
copywriting, researching alternative pain relief, keep fit
I didn't bother to copy the link to her company, as I don't want to be an accomplice to fraud...
Thats how I analyzed the page, Indel.
Based on the high BS factor, I chose to disregard it all.
Thanks for the conversation.
milo "Idonnow either, but that one sure wasn't it!"
09/14/2010 11:09 AM
I love you, man! Pax nobiscum!
Good Answers: 243
09/14/2010 11:14 AM
09/14/2010 11:17 AM
Lol.
09/14/2010 11:38 AM
Thanks for saving my eyes from all that.
I did start to read it but knew that I could stop when I came to this:
"we make use of gravitational and magnetically induced buoyancy forces in the host paramagnetic atmosphere (pressurized air or oxygen), rather than simply the diamagnetic force on the levitating object, to balance the gravitational force."
I'll just add my vote! Cheers.
09/14/2010 11:34 AM
Splarf :D
Charter Member CR4 Community Moderation Oversite Commitee
Good Answers: 243
09/14/2010 11:39 AM
Thanks for that.
Hows the dancing over the icelandic abyss going? Must be bothersome with all that volcanic ash and stuff. Your volcano eruption cancelled my last trip to Germany...
I'm dancing over just a "big honkin dark abyss," but I'm lovin' it all the same.
@LYNLYN- yes, strionging together a bunch of polysyllables will make most of our eyes glaze over...
Milo
09/14/2010 12:58 PM
I was reading your post and unconsciously read "Debbie Shimadry is a qualified pain in the narse".
Some of the links posted for evidentiary support are good but many are too much to get into. Thanks for doing the research for us.
In my many years I have come to a conclusion that one useless man is a shame, two is a law firm, and three or more is a congress. - John Adams
09/14/2010 7:25 PM
See the hydroxyl molecules all migrate through the magnetic field to the water on the other side which has all been magnetically oriented to accept only hydroxyl ions. while the hydronium ions (BTW it is H30+ not H+) are magnetically constrained in the bad water on the other side of the magic field barrier. Thus because of the increased hydroxyl, the pH increases. The high pH solution then exfoliated the cells that line the tissues that the magic water contacts, and neutralize the stomach acidity allowing a variety of bacteria to pass the acid barrier of the stomach. The new bacteria establish a new ecosystem in the intestines and begin to consume exposed "bad" tissues (intestines) that grow within the consumer. Thus in the long run we provide a better environment through natural selection to remove the most innane of the species.
Good Answers: 204
09/14/2010 7:30 PM
and also makes julienne fries!
09/13/2010 6:17 PM
You did notice they seemed to mix up ferromagnetic and paramagnetic. Also, ferromagnetic materials like many rocks can be magnetized as liquids and hold that polar directionality only once they solidify. Thus magnetized water would hold that magnetic directionality only if flash frozen in that strong field. As a liquid it would just re-orient upon reduction of the field.
09/13/2010 8:38 PM
Lots of scientific words, VERY little science! Try the wand on snake oil...
I'm with Milo and RCE.
09/13/2010 10:40 PM
I'm with you. I accept nothing until I have checked it out for myself. Accept no hearsay. I'm looking for someone who has gone past me to find the answers to questions that I have not found an answer to. In this way, I'm looking for someone who has done an experiment that I'm in the process of assembling. It is an understanding of the field strength of magnets and the effects it has on the humidity in air movement so that I can construct a math model and Excel spread sheets based on the resulting model in real time. The glib format I choose for my opener reflects the target beneficiaries that would be those who dwell in arid countries primarily. The stifling heat is a human health hazard and I thought I would try this method of developing this to the product level. I have no interest in this for monetary gain but see its potential for benefit.
09/14/2010 8:13 AM
This is just an advertizing site for their product. It cannot be considered a scientific prouf or valid information to the availability of magnetized water.
in any case, if you need to put a very powerful magnet for such a long time to obtain (what is claimed...) a magnetized water, how can such a phenomena be useful to attract the humidity from the air in any significant quantity and in a short enough cycle to be usefull for dehumidifying the amount of air required per a reasonable unit of time ...?! In reply to the OP question.
09/16/2010 3:01 AM
Everybody knows that theories are only made after something has been observed- the greatest discoveries in history were made by people thinking outside the accepted- yes some concepts put forward are wrong- but even scientists are willing to reject the last theory for the later theory if the latter works better!. So dyed-in-the wool proponents of an older theory really need to accept that what they believe as fact could be wrong- but no-one will ever know unless somebody experiments.!. Kind regards.
Good Answers: 130
09/16/2010 4:13 AM
"if the latter works better"
No not really. Perhaps if the latter is supported by repeatable results and fully defined inputs and process protocols.
E.g. "cold fusion" - claimed - yes. repeatable - not yet. because "How" and "Why" - not sure. "proved" - no.
It's possible that water is magnetic, in certain conditions, as the atoms are, in certain conditions. It could be a matter of a sufficiently intense field.
But you need to get to the point of surety that no other extraneous influences are producing the 'observable effect' - or proof that it is magnetism, not EMR, not a voltage, not an aerodynamic phenomena, not the WD40 they got washed in, not static, not, not ....
And to do that, it is helpful to have some knowledge of each 'possible' other discipline/field/dynamic/skill set.
All 'discoveries' are much assisted by this input of outside knowledge process of others throwing in opinions on what else it might be and demanding suggesting it 'eliminated' from cause.
For instance it is amazing how literally thousands of 'cooking inventions' come to nothing because the 'perceived need/problem' is fulfilled/solved, when the inventor's efforts in perfecting - teach him/her 'how cooking actually works'.
Or try not to get in a knot over a essential part of the development/proof process.
09/16/2010 9:29 AM
The OP is correct.
Water (Pure) is diamagnetic and hence is repelled by magnet.
However the magnetic susceptibility of water is very low (if I remember it is of the order of 10-5. And that makes the magnetic field required to move it appreciably a bit too large (and that then translates to the requirement of energy)
it is of the order of 107T/m2 for water and that makes the exercise a bit too inefficient and also there is the hazards included in trying to contain the field.
Any one interested may check CRC handbook of Physics and Chemistry for exact values (Volume susceptibility 0.91x10-6) or study diamagnetism.
UD15
Good Answers: 69
09/16/2010 10:10 AM
I guess you've never seen a rusty magnet, I've had to buff clean some of them or dispose off for this and other reasons (weakened).
If you are in a moist-saturated weather, the only choice you have for evaporating your cooler's water is heating it, but that will be even less unpleasant !.
You need to change to an air conditioner, instead of an evaporative cooler.
Yahlasit
09/16/2010 5:44 PM
...back to the original question: "how to" reduce humidity?
• Magnet = NO.
• Hygroscopic materials = YES.
...they absorb water vapor (humidity) from the air, which you subsequently "drive-out" by heating (think solar here).
In reply to #68
09/16/2010 6:14 PM
That could become pretty expensive in a place where they regularly get Fog.
In reply to #69
09/16/2010 7:06 PM
...which expensive? (a) buying magnets that don't work, or (b) alternative heating source to solar?
...last I heard, trees and lumber still grow on mountain tops.
In reply to #70
10/04/2010 11:31 AM
True, but burning trees as a energy source is only really legal anymore in a few backward locations, i.e. barren deserts, areas of deep snow cover, and a few 3rd world countries, though even most 3rd world countries have outlawed it (even if they can not enforce it in the marxist rebel held zones).
Good Answers: 243
In reply to #72
10/04/2010 11:47 AM
Who you calling backward? OHIO? Pennsylvania?
I have heated with wood, and I know many people that do.
Like my neighbors.
Note, I also heated with wood when I lived in Georgia, USA but I chose not to add it to my initial response for fear of helping make your point...
Milo "Ohio isn't a 3rd world country, most days..."
Good Answers: 204
In reply to #72
10/04/2010 12:27 PM
"...burning trees as a energy source is only really legal anymore..."
what the heck are you talking about?? that is simply not true.
In reply to #72
10/04/2010 12:56 PM
Even in California (where I live), burning wood as a heat source is only prohibited where pollution is a problem, meaning down in the valleys and in areas of dense population. I get a large portion of my heat by burning wood, and at least one of my neighbors has no other source of heat besides wood. Cutting and splitting wood is probably the most important activity keeping me fit!
If I did not cut and use all the fallen trees for firewood, the fire danger would be increasing even more than it is, and the smoke produced when it did burn would be much worse that that of my fireplace! It would most likely occur during the summer, when there is little wind (other than that created by the fire) and no rain to disperse and settle the ashes. Add to that all the plastics of burning houses etc., and you really have a bad situation!
All wood that grows and dies MUST be used for constructive purposes, as fuel, otherwise disposed of, or decompose. I prefer to have the fuel portion of that equation used gradually to heat my house to just warm, rather than all at once to ashes. Allowing the wood to decompose takes many decades for larger logs, and the result still returns the CO2 to the atmosphere; meanwhile, the probability of adding fuel to a wildfire is high. I prefer to use decomposition only for those parts that will provide mulch within a year or two.
In reply to #75
10/04/2010 2:34 PM
Burning wood in fireplaces and such in very rural areas, areas in the SNOW, very desolate areas like the deserts, or well economically depressed areas is still common. But using wood for a fuel source for energy for other than residential heating is not. I suspect that you guys may have missed the part about the snow, and the implication by saying it was for energy generation that the energy was for recovery of desicants, in there and just read 3rd world. And well I would not fault Georgia over Ohio, the economy in the rust belt has never been all that good to look down on Georgia and in current circumstance may be substantially worse than Georgia.
BTW in California burning firewood is also prohibitted in areas prone to wild fires and along nearly all of the coast, unless grandfathered in with a fireplace or stove installed prior to regulation, and there are allowed burn day restrictions, it is not just about smog (though some people still do it and there is no real enforcement in some areas). Even then I don't know of anywhere they burn wood for energy, outside of residential heating and maybe a few waste to energy plant (which actually process the waste typically gasifying it), which is the implication of the discussion that they would recover the dessicants by using wood burning heat.
Good Answers: 204
In reply to #76
10/04/2010 2:38 PM
okay... I get you now.
Good Answers: 243
In reply to #76
10/04/2010 3:06 PM
Hey, I'm still trying to figure out your stomach acid lining ecosystem comments with the magic field separating the bad water many posts above.
I've lived in both Georgia and Ohio. I've been president of friends of the library in both.
In Ohio, our library had books on subjects other than civil war geneaology. In Georgia, ehhh, not so much.
I've had more dealings with your SCAQMD than I care to admit.
I just got a mailing form them last friday - automatic increase in Regulation III fees based on Consumer Price Index.
Thanks for the further explanation.
Milo
In reply to #78
10/04/2010 5:04 PM
The secret is in the application of good magic fields, instead of the potential for bad magic fields. Bad magic fields would have the reverse effect and increase the acidity, though the ends might be the same but instead of natural selection through bacterial infection, it might be due to excessive mucosal erosion of the esophygeal and stomach lining leading to hemorrhaging and perforations.
Good Answers: 243
In reply to #79
10/04/2010 5:14 PM
Ahhhhhhhhhhhhh!
milo
In reply to #79
10/04/2010 10:54 PM
Will you please tell us which magnetic fields are 'good', and which are 'bad'. How do you measure the level of goodness and/or badness?
You convey the impression that acidic water is bad, and that it is desirable for water to have a pH higher than 7. Why? Virtually every restaurant (at least in the USA) has lemons available for adding to your drinking water. Lemons are clearly acidic! Can you name any basic (pH higher than 7) food item that you would willingly add to your drinking water? I'm NOT talking about foods that raise the pH of the urine, but rather foods that have a pH above 7. There has to be a natural reason that acidic (within reasonable limits) foods taste good and basic foods taste bad. Or is it only my taste buds that convey that message?
In reply to #82
01/03/2011 12:12 PM
Magic fields, not necessarily magnetic, but definitely magic.
Good Answers: 114
#81
In reply to #76
10/04/2010 9:52 PM
what about
things are different once you cross the grapevine, the ban on open burning of ag waste has put several co-gens back on line
there is not a ban on wood stoves in areas prone to wild fires [spark screens are required]
but there are restrictions on open burning in the dry months [ I have a burn permit & will start burning brush piles any day now]
you are correct that using wood heat to recover dissicants would be an unusual practice.
#83
01/01/2011 12:17 AM
My predictions offered on this thread are proven to be correct. Your efforts to support your contra-opinions are unsupported opinion. Since you gave me nothing, work or proofs you get nothing back. I did my work and you did not. So why should you be enlightened in the dark place that is your mind? Good bye and may the crudity of your lackluster opinions keep you entertained where you are.
Good Answers: 130
#84
In reply to #83
01/01/2011 2:34 AM
Thank you
In reply to #83
01/01/2011 2:40 AM
Who the hell are you talking to?
Good Answers: 204
#86
In reply to #85
01/01/2011 11:42 AM
It's Crudité... as in Joe Dirté
Register to Reply 87 comments
34point5 (6); 70AARCuda (2); Anonymous Poster (2); chrisg288 (6); dkwarner (8); Garthh (2); gfmlcka (1); indel (4); jack of all trades (1); kramarat (1); LAA_Lucke (7); lyn (3); mareng (1); Marjer2 (1); Milo (9); Neil Kwyrer (4); ozzb (1); pnaban (1); PWSlack (1); RCE (9); robertgrist (9); Tornado (1); Usbport (1); user-deleted-1105 (3); VisiGuest (1); Yahlasit (2)
