Hi, On a CNC machine it has just serial port connection. It is a fairly old unit. However it communicates with a PC via a Windows based software program.
Due to the newer laptops not having a serial port, we are using a USB to Serial Port Converter.
However the physical cable that links between the CNC and the USB 2 Serial Cable is just a normal interface cable.
I am looking for a solution to get rid of these cables and use just wireless.
Is there an Industrial version of Serial to Wireless that can be connected on this CNC machine.
And in turn can I use the laptops normal wireless connection to communicate to it.
Please remember that the software used connects using normal Comm Ports IRQ's and Comm Ports Addresses.
I would appreciate any replies that may be of use.
Thanking You,
Adrian.
