Previous in Forum: Lightning Arrestor   Next in Forum: Stabilizing Resistor in REF Protection
50 Watt LED Driver, Power Supply
09/14/2010 4:10 PM
Hi,
I just got a Phlatlight LED. It will draw up to 13.5 A at around 3-4.5 V (cbt-90)
Now I need a small driver, if possible dimmable. Up to 10 A is enough for my application.
But I cant find any drivers which deliver more than 3 A. Is there a simple circuit, or IC which would support my needs.
I will be using a 13.8 V power supply.
Can anybody give some help?
many regards
johnny
Good Answers: 58
Re: 50 Watt LED driver, power supply
09/14/2010 4:56 PM
Johnny,
Google came up with this http://www.google.com/products?q=led+driver&rls=com.microsoft:en-us:IE-SearchBox&oe=&um=1&ie=UTF-8&ei=PN6PTOjzMMH58Abt2o2NDg&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CEEQrQQwAg
After a VERY brief browse, none appeared to have 10A output. This site does list several manufacturers so maybe you will want to call a few and see what they have to offer other than what is on this site.
This site http://www.exar.com/Files/Documents/DesignSolution66.pdf has a driver - 15V in - 3.5-4.5V out - 10A nominal – 25A peak capable LED Driver
You may even consider a Google search "PhlatLight 10A Driver"
Re: 50 Watt LED Driver, Power Supply
09/15/2010 12:04 AM
If you have some technical background why not try computer power supply.
Its 5V is well rated above 15A
09/15/2010 4:18 AM
Hi,
I did consider a PC power supply, but I have to regulate the current to 10 A. LEDs are not all the same, and just 0.1 V more or less will result in a massive current change, which can quickly destroy the LED.
Anonymous Poster (1); Haajee (1); KJK/USA (1)
You might be interested in: LED Drivers, LED Lamps, Light Emitting Diodes (LED)
