Previous in Forum: Heat Transfer   Next in Forum: Finding Diamonds
20 comments
Tank Weight
09/15/2010 3:51 PM
I need to know the weight of a tank that is for ammonia storage. The dimensions are 40ft x 8ft tall by approx. 3/8in thick.
Re: Tank weight
09/15/2010 4:12 PM
Material?
Charlie don't surf.
Re: Tank weight
09/15/2010 4:29 PM
40 ft diameter or circumfrence?
Sounds like homework to me.
Re: Tank weight
09/15/2010 9:02 PM
Presuming it includes a bottom, does it also include a top? The given plate thickness is not enough to make this a pressure vessel; how are you controlling the ammonia pressure? Is thermal insulation to be included in the tank weight?
Good Answers: 123
Re: Tank weight
09/15/2010 9:58 PM
There is not a lot to go on here, but, If the tank is not reinforced because it is pressurized, and it is made of steel, a rough figure to work with is 2.5 pounds per gallon. Good luck.
Bob
Reply Score 1 for Off Topic
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
Re: Tank weight
09/15/2010 11:18 PM
More information, please! Material, shape, unusual design features, etc.
Speak softly and carry a big stick.
Re: Tank weight
09/16/2010 2:05 AM
If the material is carbon steel and the tank is empty, the weight is aproximately 8000 kg, this value is only for estimation, if you need a value more precise, we need more information.
Regards,
Re: Tank weight
09/16/2010 2:45 AM
What's it made of - balsa wood? Osmium?
Good Answers: 18
Re: Tank weight
09/16/2010 5:39 AM
You dont provide enough info about the tank material, however, since I know that Ammonia is mild steel friendly i'll try and work this out. Bear in mind that "feet and inches" is foreign to me, thus i will work in metric. Remember that mass= volume *density and the density of mild steel is typically 7800 kg/cu meter. Therefor the volume of the tank comes to 0.8905 cu/m * density =6943kg. The bottom, assuming its not conical have a volume of 1.1111+ cu/m with a weight of 8671 kg. These dimensions (and calcs) suggests that the diameter is probaly not the stated 40 ft but may be circumference.
Thus the picture changes somewhat. now the tank steel volume becomes 0.283 cu/m, and a weight = 2210 kg. For the bottom the volume = 0.1126 cu/m at 878kg.
Whatever your dimensions, you now add 2210 to 878 to get 3088 kg for open top tank. If the tank have a top add another 878kg to the already added kgs (878+878+2210=3966). Of course this is ONLY the steel weight without legs or appurtenances and empty. Either of above calcs (if accurate and correct) will help you out, you basically take your pick.
Always learning
Re: Tank weight
09/16/2010 7:59 AM
<...3966[kg]...>
PVC is also ammonia-friendly, and a suitable tank in it would weigh rather less.
Until the OP gives the forum some more information, one question might be "How heavy does the tank need to be?"
Good Answers: 130
Re: Tank weight
09/16/2010 8:32 AM
3/8 might be a bit thin for PVC at that depth and diameter.
(I'd think ms at 7.2 g/cc?, but be as ornery as you like)
Good Answers: 18
Re: Tank weight
09/17/2010 2:48 AM
The OP stated he had a tank of stated dimensions. He did not ask what material he should use, and in fact I used mild steel because i know that it is ammonia friendly, not because I say he must use steel, or that you cannot use anything else. Hope this response takes the "near" sting out of your post. AND he wanted to know how heavy IS the tank......
Always learning
Re: Tank weight
09/16/2010 6:48 AM
Empty or full?
Good Answers: 25
Re: Tank weight
09/16/2010 7:35 AM
Many a times we get such questions when Guests asking questions does not respond.It will be better to not respond to such questions.
Re: Tank weight
09/16/2010 7:56 AM
Don't do it, then!
Re: Tank weight
09/16/2010 7:46 AM
Re: Tank weight
09/16/2010 3:56 PM
I'm so glad to hear that you must know the weight of a tank. I hope that your entire career hinges on the need to know. As you should notice from the large number of unanswered questions, you have not presented enough information for anyone to even attempt to give you an answer.
But you and others here may wonder why I'm so happy that you need to know the weight of this tank. Well your knowledge of your problem combined with your ability to communicate your problem will quickly guarantee your complete failure in anything that resembles an engineering career. By failing you will be making the first step in learning on your own or unemployment. That is unless you can learn to either do your own work yourself or you learn to listen and communicate to others willing to help you solve your problems.
Reply Off Topic (Score 4)
Hobbies - Hunting - Deer and Birds Hobbies - HAM Radio - Achieved Ham Radio license in 2008 Hobbies - Fishing - Fisherman United States - US - Statue of Liberty - Know freedom, no tyranny.  Know tyranny, no freedom. Hobbies - DIY Welding - Beginner
Good Answers: 19
Re: Tank weight
09/16/2010 5:29 PM
That was stated excellently!!!
Go green, use a solar powered light saber...
Re: Tank weight
09/17/2010 5:18 AM
Unfortunately he's probably on a fast track to management rather than unemployment.
Re: Tank weight
09/16/2010 7:31 PM
A few random issues:
1. At atmospheric pressure, liquid ammonia is -28°F. PVC would be too brittle at that temperature. Even SA-36 steel might not suffice, but SA285-C or SA516 would do.
2. Liquid ammonia at -28°F weighs about 40 lb/ft3, or about 5.5 lb/gallon.
3. Some kind of refrigeration system may be required.
Good Answers: 130
Re: Tank weight
09/16/2010 7:59 PM
Just to add to that "random";
"Ammonia" might mean granular fertilizer or ammonia gas (at some pressure?)
Or 3/8 'average' might mean banded construction, or staged wall thickness.
"Tank" might mean silo or hopper.
"Weight" might mean for shipping weight (empty) or for foundation loading full.
Or ..... 'ammonia' is random 'data spillage' in one of those assignment questions written (lazily) around a picture in Perry's. "Find the weight of the tank on pp ##"
Reply to Forum Thread 20 comments
34point5 (2); ARROW (1); bob c (1); jvrj (2); lyn (1); Matt Skywalker (1); PWSlack (3); Randall (3); redfred (1); standarded (1); stevem (1); suresh sharma (1); Tornado (2)
