Previous in Forum: Convert Pressure Drop from SCFM for Water   Next in Forum: Double Skinned Ahus
Flue Gas Volume
09/15/2010 10:25 PM
I have a boiler with flue gas volume (at 20 degree C and 1 bar) is 510,000m3/h. How can I calculate the volume at 400degree C and 0.5 bar?
Pathfinder Tags: flue gas
Re: Flue Gas Volume
09/16/2010 12:12 AM
P1V1/T1 = P2V2/T2.
(1)(510,000)(273+20) = (0.5)(V2)(273+400) [Assuming bar absolute.]; or
(1+1)(510)(293) = (1+0.5)(V2)(673) [Assuming barg.]
(Said the fly, let us flee; said the flea, let us fly; so they flew through the flaw in the flue.)
Good Answers: 19
Re: Flue Gas Volume
09/16/2010 11:06 PM
(Said the fly, let us flee; said the flea, let us fly; so they flew through the flaw in the flue.)........she sells sea shells along the sea shore . Tounge twister
Re: Flue Gas Volume
09/17/2010 3:53 AM
If you want to calculate the gas volume of the exhaust gases, at an earlier stage (400 deg C and 0.5 bar(g), could describe the burner exit), and you want to base your calculation on the gas volume at 20 deg C and 1 bar(Abs), then you should consider also the volume of the water vapour that has been condensated.
Register to Reply 3 comments
Anonymous Poster (1); ducon (1); Tornado (1)
