Hi there
After changing the Motherboard on a laptop and installing a larger HDD, a few new ( re) installations fail, saying: " you are not licensed to use this software on this computer".
It appears, that the program license must somehow match up with the serial number of the chip, the HDD, or both.
Is there a way to change values ( in the BIOS ? ) to the original (serial?)-number to avoid having to buy new software?
Would the Serial # stored in the BIOS be the same as the computers serial number on the label underneath? If not, how can I read it out from the BIOS?
I did make a HD Image using acronis, but loading this does not solve the problem.
Any help for a non-specialist?
