Previous in Forum: Storage Tanks   Next in Forum: Eccentric Loading on Vessel
18 comments
PSI and CFM from Exhaust of Engine
09/20/2010 8:44 PM
Say I have a dodge/ford/chevy v8 engine and I run it at 2500 rpm. How much psi and cfm are coming out of the exhaust? Any engine will do.
Re: psi and cfm from exhaust of engine
09/20/2010 8:49 PM
In a properly designed exhaust system the back pressure will vary depending on where you take the reading. About .5 to 3 PSI is a normal average. At 2,500 RPM it's not much.
The volumetric output of the engine is displacement x rpm. Give or take a little because it is momentarily expanded by heat. A 350 cu in Chevy engine will produce roughly 350 cu in of exhaust flow per revolution. Consider it a positive displacement air pump.
I've visited test facilities (in Tony Stewart's home town) and seen the headers glow cherry red wherever there is a bend in the pipe. That's back pressure.
09/20/2010 9:12 PM
is back pressure bad for the engine?
09/20/2010 11:46 PM
No, not necessarily.
What do you want?
Good Answers: 150
09/21/2010 10:50 PM
Depends on the amount. Eengines develop the most power when backpressure is lowest. The more backpressure you have, the more burned exhaust gasses are left in the cylinder when the exhaust valve closes. backpressure isn't so much bad for the engine so much as bad for power. It won't damage the engine, but it will shave a few horsepower off the top end.
Who is John Galt?
Good Answers: 137
09/21/2010 6:33 AM
Formula displacement x rpm is right for a 2-stroke. For a 4-stroke it's half that.
Cheers..........Codey
Good Answers: 299
09/21/2010 6:41 AM
Good catch Codey.
09/21/2010 9:08 AM
You are right, of course. Good catch. Gettin' sloppy in my old age.
Cheers.
09/22/2010 7:24 AM
Isn't it a quarter of the rpm for a 4-stroke? - ie exhaust at every fourth stroke.
09/22/2010 7:38 AM
In a 4-stroke engine, there are two strokes per revolution. Intake and compression in one revolution. Then ignition and exhaust in the next revolution. That gives you the exhaust stroke (and other strokes) every other revolution. Now I can't get that song out of my head.
coachdurbin
Good Answers: 18
09/27/2010 2:07 AM
Always learning
Good Answers: 137
09/22/2010 8:48 AM
No, each stroke takes half a revolution, not a quarter. So a 2-stroke takes 1 rev to do a full cycle, a 4-stroke takes 2 revs. A 4-stroke intakes/exhausts the engine swept volume (= engine capacity) every 2 revs.
Cheers........Codey
Good Answers: 18
09/22/2010 4:32 AM
Well said LYN, except that you dont mention inch to feet conversion, as in cFm( maybe the OP dont know the difference) and cherry red headers from back pressure? Surely its the combustion heat reddening the headers? I remember in MY younger days in the army, we kept our coffee bottle on the headers of a Bedford truck, and at night, at speed, on a long drive, these headers glowed cherry red until the engine slowed down again.
Always learning
09/22/2010 9:11 AM
The engines I observed on the test stands had exhaust pipes with bends in several places along their path. Only the bends were glowing. Straight sections of pipe were a normal color.
These were Ford SHO engines running at wide open throttle.
This facility had a two mile test track. When they took vehicles out for testing, their warm-up procedure was two laps around the track in low gear at WOT.
Good Answers: 150
09/22/2010 9:27 AM
Lyn, I think what you were seeing was where hot exhaust, being forced to turn a corner became turbulent and because of the turbulence dumped more of it's heat into the walls of the manifold in the turn. This is a lesson I learned when working with heat sinks for electronics. Laminar airflow tends to form a "skin" of relatively stagnant air along the surface of the heat sink (in this case the wall of the exhaust manifold.) which acts as an insulation blanket. But when the laminar airflow is disrupted (by a turn in the pipe or a serrated edge on a heat sink fin) that blanket breaks down and allows the hotter air to impinge on the pipe wall, spot heating that part of the pipe.
Who is John Galt?
09/22/2010 11:09 AM
Of course. No argument there. But, does not turbulence equal back pressure in this case?
Good Answers: 150
09/22/2010 1:07 PM
Eh, yeah, but it isn't backpressure itself doing it, the turbulence CAUSES backpressure but it is more of a symptom in this case.
Who is John Galt?
Hobbies - CNC - New Member Engineering Fields - Mechanical Engineering - New Member
Re: PSI and CFM from Exhaust of Engine
09/21/2010 10:59 PM
Don't forget throttle position......
09/26/2010 6:19 AM
Re posts 11 & 12
Obvious - just having a senior moment.
Thanks Codey & Coachdurbin.
Reply to Forum Thread 18 comments
Anonymous Poster (1); coachdurbin (1); Codemaster (2); Doorman (1); horace40 (2); jvrj (2); lyn (5); Rorschach (3); the wrench (1)
