Previous in Forum: PE Powder Going Out to ATM Through Equalizing Line   Next in Forum: Double Flange Gate Valve
CFD Analysis of Two Phase Flow
09/21/2010 10:08 AM
I am doing CFD analysis of two phase (Water-Air) flow in T junction vertical channel of 2 mm diameter. Will I gravity affects on flow patterns for such a mini channel?
Re: CFD Analysis of two phase flow
09/21/2010 10:30 AM
If it's 2-phase in that section, I would think yes.
Re: CFD Analysis of Two Phase Flow
09/21/2010 11:27 AM
It depends upon the strength of the gravitational field.
What about swirl, though?
Good Answers: 183
09/22/2010 4:29 AM
If you mention 2 phase flow this means that you have air bubbles. The effect of gravity will be function of the relative bubble dimension with respect to the channel diameter.
Around every bubble there is a layer which has a thickness depending on the relative speed between bubble and fluid flow.
Register to Reply 3 comments
Mikerho (1); nick name (1); PWSlack (1)
