Previous in Forum: Coating of Carbon Steel Plate for Etching   Next in Forum: PH Formula?
Draining for Sample Analysis
09/23/2010 4:35 AM
Case Study:
The product in a core pipe with steam jacketed pipe; the product temperature reaches up to 250 oc and P down to 1atm. To drain it, it is impossible to drain the product when there is pressure difference relative to Atm. my question is, how to quench the P in order to drain the product for laboratory analysis. What meachansim can be applied on!
product properties:
palm oil ester base
non hazardous
comply to ISO 22000
Re: Draining for Sample Analysis
09/23/2010 6:36 PM
Install a small branch off the main pipe, aimed down. Put two valves in series, with enough pipe between to contain an adequate sample. To take a sample, close the lower valve; open the upper valve to fill the pipe; close the upper valve; and open the lower valve to drain the sample.
09/29/2010 11:01 PM
the above is the Reactors (R1A and R1B) convey to a common pipe line by a P3.
Condition of reactor:
400mbara
240 degree c
Condition of P3
Desgination T and P resp 240 and -1/4.5 to -1/4.
pipe line (jacketed)
my question is would it be possible to drain the productwith such condition by 2407, drain valve? or we any special piping design??? any innovative alternative??
09/30/2010 12:18 AM
amendment " we need* any design........"
Register to Reply 3 comments
