I have to synch 4 x 750 kVA cummins DG sets by PLC (Allen bredly - micrologix 1400). No any relay (i.e. woodward or CSPC) to be used. Cummins DG sets are equipped with PCC 2100 + Aux. cards. For reverse power protection, RPR relay is used. My doubts are as follows :
1) I am giving voltage and frequency input to PLC through multi function meter. We have checked whether it matches with PLC or not and it found OK. Now during sync. process, i have programmed the plc to match the values of frequency, voltages and phase angle. is it ok or any other thing to be programmed?
2) How auto load sharing can be done? What to be done to take the load on DG and to unload the DG set? Can it be done by increasing / decreasing the speed?
3) Is there any major risk to do synchronising without any special relay?
