Previous in Forum: Synchronising of DG sets by PLC   Next in Forum: Medium & Low Voltage Cable
Can We Use 3P+N LV Breaker For Single Phase Supply Load
09/27/2010 7:05 AM
Hello any one can explain me about the below issue
What will happen if i use 3P+N LV breaker (say 32Amps breaker) for single phase supply load. i mean thereby leaving two poles in the breaker empty and use single pole and nuetral for connecting the load.Is any impact on this or i need to do looping of other two pole of breaker and make to Single phase and neutral....Kindly advice me on this issue if anyone knows......
Good Answers: 181
Re: Can we use 3P+N LV breaker for single phase supply load
09/27/2010 7:38 AM
Oh No not again ! ! ! !
Use search CR4
Re: Can We Use 3P+N LV Breaker For Single Phase Supply Load
09/27/2010 8:52 AM
Yes you can use TPN breaker for single phase supply. The 3 phases should be linked.
Sushma
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
09/27/2010 8:55 AM
go wit looping
shamith gambhir, electrical engineer
09/27/2010 9:27 AM
Just connect all the three phases in series connection with the single phase supply available.
09/27/2010 10:10 AM
dear friend
it's ok but you know 3P is more expensive in compair with 1P breaker and needs more
space for instalation
thanks
anbarasu.pr (1); Anonymous Poster (1); SHAMITHGAMBHIR1 (1); Sushma (1); TonyS (1)
