Previous in Forum: R-Pad Fabrication Detail   Next in Forum: -MACHINE ELEMENTS-
Compression vs Temp
09/29/2010 1:36 AM
when air is compressed, its temperature increases, what is the relation between the compression of air (pressure) and its temperature ?
Re: compression vs temp
09/29/2010 2:23 AM
P*T^(n-1)=C
P=pressure(pascal)
T=temperature(Kelvin)
n= a constant
for isentropic compression n=k k=1,4 for air
isentropic means no heat is added or removed. Because heat is always added by the compressor, it doesn't have 100% efficiency, this isn't 100% accurate, but a good guess.
For better accuracy you should read some Thermodynamics
Hope this will help
Good Answers: 183
09/29/2010 5:49 AM
You are right with your last sentence:
(1) p*v=R*T
(2) p*v^m=C m = k if isentropic process and m=1 if isotherm
from (2) → v^m= C*p^(-1) → v= C^(1/m)*p^(-1/m) introduce in (1)
p*[C^(1/m)*p^(-1/m)]/R= T → p^(1-1/m)*(C^(1/m)/R)=T →
p^(1-(1/m))/T= Constant
Register to Reply 2 comments
