Previous in Forum: Heat Detector   Next in Forum: 132 KV GIS Substation Space Requirement
Diesel Generator Selection
09/29/2010 2:49 AM
Please explain the main consideration for a selection of a generator for below requirment.
I want to run a 100kW, 415V , 92% efficiency motor with DOL starter on a disel generator set, kindly advise how to select the generator kVA for 100kw , in general what are the factors that need to be considered in selection a generation KVA( the generator loading is with only one motor of above said rating)
Good Answers: 181
Re: Disel generator selection
09/29/2010 3:13 AM
You really should look at a soft start unit rather than DOL otherwise your going to be spending a lot of money for a generator with enough punch to get the drive going.
09/29/2010 4:14 AM
Why not cut out all the electrical confetti and simply drive whatever device this is right off the engine? (There may be good reasons, but....)
09/29/2010 4:53 AM
Load of Motor is =100 KW
KVA Calculated of Motor= 100/0.85 = 117.65 KVA
Starting KVA Load = 6x 117.65 = 709 KVA
Combined Impedence & Voltage Drop is , 4% DG impedance and a voltage drop of 15%, then the DG rating for Load would be = (Impedence/Voltage Drop) x Calculated Load KVA * Design Margin
Design Margin is = 1.15
DG rating for Load =(4/15)*709*1.15 = 218 KVA
DG rating selected = calc KVA * Diversity factor =218*1.5=327 KVA
Reply Score 1 for Off Topic
Good Answers: 170
09/29/2010 9:38 AM
Excellent! GA to you!
electricalexpert65 (1); nadim7862 (1); TonyS (1); Tornado (1)
