Previous in Forum: Welding of Instrumentation Tubing (ASME)   Next in Forum: Piping Fabrication Tolerances
API 650
09/29/2010 4:29 PM
API 650 uses a live load of 20 psf (lb/ft2) in roof design.
A normal person weighs about 200 lbs. Assuming a standing area of 1 sqare feet, this results in a loading of 200 psf.
Is it safe to walk on the roof of API 650 tank ?
Your thoughts please.
Thanks
Re: API 650
09/30/2010 1:58 AM
Going at this simply, if you assume a standing area of 1 ft2, the answer is no. Looking at this differently, to support 200 lb, you need 10 ft2. So if people stay around 3 ft apart the loading is in the ball park. The question is, does the design of the roof of the tank allow the weight to be distributed to around 3+ ft away without permanent deformation, damage, or failure? If your answer is "I don't know" , then my answer would be no.
You might be interested in: Roof Curbs, Roof and Floor Trusses
