Previous in Forum: Drum Level Compensation   Next in Forum: Level Measurment
Calibration of Control Valve
09/30/2010 3:06 AM
Can any one help me to tell me about the procedure of control valve calibration?
Re: calibration of control valve.
09/30/2010 6:51 AM
First you ensure I/P convertor working is oK by applying 4 mA & 20 mA DC current to it correspond to 03 psi & 15 psi output pressure then by appling the same current to I/P, calibrate the Valve positioner for rated out put to control for correspond 0 % & 100 % opening of control valve.
In case you have I/P convertor cum valve positioner, Apply 4 mA DC current & set the rated output pressure by zero adjustment for 0 % opening of control valve. Now Apply 20 mA DC current & set the rated output pressure by Span adjustment for 100 % opening of control valve.
10/01/2010 3:20 AM
Thank you for your HELP.
can you please tell me. Is this procedure applicable to AC 4mA-20mA?
10/01/2010 10:11 AM
No.
You may try it & see hunting in o/p of I/P as well as control valve due to bi- directional property of AC current.
Re: Calibration of Control Valve
10/01/2010 11:18 PM
Usualy control valve(cv),received signal pneumatic 3 to 15 psi or 6 to 30 psi.this cv can direct received signal or use I/P converter.we talk about cv with I/P.
instal supply about 30 psi to I/P.connect signal cable to I/P,if you use mA calibrator,please give input 4mA,look at position scale of opening cv must be 0% (use zero adj I/P to correct opening),give 20 mA and opening will be 100% (use span adj for correct),next give 8 mA for 25%,12mA for 50% and 16mA for 75%.Remember you will found control valve ATO (air to open) or ATC ( air to close).good luck)
Re: Calibration of Pressure Reducing Valve(PRV)
10/03/2010 2:37 AM
First of all thank you for your reply against my query.
then can you help me to tell the procedure of calibration and maintenance of Pressure Regulating Valve(PRV). And how can i do maintenance and calibration of positioner in PRV?
10/04/2010 12:41 PM
Calibration? Eh?
They can be set up, if that is what is meant by the question, by following the manufacturer's instructions.
01/19/2011 9:12 PM
control valve can be calibrated automatically by using hart communicator. just follow the step instructor from the calibrator.
Register to Reply 7 comments
adityaEI (2); anilsahu (2); Anonymous Poster (2); PWSlack (1)
