I am assuming that a 4 cylinder 2000 cc 2 valve single over head cam with carby and spark ignited engine is using 29.55 cc/min to idle at 750 rpm from the figures I have been advised on = 5kw of fuel at 30% thermally efficient.
My modified engine uses approx 9.8 cc/min at 750 rpm some 70% less.
Is the 29.55 cc/min to large because my thermal efficiency works out to be 86%?
My engine is different that what the big boys are doing.
My timing curve does not flattern out at 3000 rpm like most other engines.
I have an idle fuel consumption test on youtube if anybody is interested.
