Previous in Forum: Timing Theory and Science   Next in Forum: How can I Derate my Engine Efficiency from 86%?
Oil Spec
09/29/2010 8:26 PM
I have been told that if my car is using oil spec 15w40, The Spec should be change after running certanly amount of Kilometers. ¿ Do I should change to another SPEC with the time?
Thanks in advance for toy re`ply.
Best regards Orangel
Re: Oil Spec
09/29/2010 10:33 PM
No, just replace the old oil with new oil of the same type as it has a set life time depending on the engine and driving conditions (hence the suggested time to replace). General information should be available on the side of the oil container or from a local auto mechanic, or in the example link below if you are confused as to what type to use for your vehicle and application.
http://en.wikipedia.org/wiki/Motor_oil
Re: Oil Spec
09/30/2010 12:11 AM
Although this post technically violates Rule #75 because it contains two sentences, I believe that it still falls within the general guidelines.
Re: Oil Spec
09/30/2010 12:52 AM
I've heard of this idea, but I don't know if it is true. The purported rationale is that as the piston rings wear and develop some greater clearance, a heavier oil will seal better. If so,in your case you might go to 20W-40. Does the engine manual mention anything like this?
Good Answers: 16
Re: Oil Spec
09/30/2010 5:41 AM
Adhere to the OEM specifications.
Remember that the best oil for any engine is clean oil.
jack of all trades (1); lyn (1); Tim in Mexico (1); Tornado (1)
