Previous in Forum: 2001 Chevy Cavalier Starting Problem   Next in Forum: Oil Spec
Timing Theory and Science
09/29/2010 12:17 AM
What sources would you recommend for hardcore timing theory and science? Not the basics, but more like why do we want peak CC pressure at 10-15 degrees ATDC, and what is the actual mathematical relationship of MAP and timing, and RPM and timing. Not opinions and practices, but how we scientifically came to the ignition timing we use today.
Please no responses of the form "every engine is different"; that is obvious, and it is also obvious that all internal combustion engines function under the same laws of physics, and timing can be discussed without knowing the exact configuration.
Re: timing theory and science
09/29/2010 2:42 AM
It's the geometry of a circle.
If you have peak pressure too near the top you are just pushing straight down the conrod almost in line with the big end and main bearings and not generation any turning force.
E.G Before TDC would be turning the wrong way... at TDC would give no turning at all...a little after TDC starts to exert a turning moment.
09/29/2010 9:46 AM
Del, you are of course correct, but I'm looking for more detail and hard science. As soon as the combustion process starts (at some time before TDC) pressure builds. But why do we specify peak pressure at 10-15 degrees ATDC? How did we arrive at that figure? Was it trial and error testing on a dyno, or is there science to derive it?
09/29/2010 9:50 AM
If you understand that much then you should be able to work it out yourself.
You probably just need to look at sin tables for angles from 0-20 degrees.
It has doubtless been derived empirically though.
Maths and science isn't what makes stuff happen, it merely explains why, or if you are lucky helps you predict what will happen.
All the paperwork and calculations in the world won't effect the reality, which has probably been long since established by the engine tuning fraternity.
09/29/2010 6:56 AM
In another part of CR4 the OP developed an ABS trailer for hauling a canoe over rough terrain. Although everything had a mathematical component, it was not discussed.
While I appreciate the rigor sometimes to, there are times when you develop your project, then maybe go back and fit the math to it.
There are lot of times that you have to be satisfied to just make a log-log straight line and call that science. Nothing in life is linear, everything is hyperbolic.
Who is so ignorant as not to know that knights-errant are beyond all jurisdiction, their only law their swords, while their charter is their mettle and their will is their decrees? Don Quixote
Re: Timing Theory and Science
09/29/2010 10:50 AM
I think you are trying to find a precise explanation for an imprecise result.
A cursory look at a sketch of the geometry or a brief experiment pedalling a bicycle would indicate an angle in the region of between say 5 and 45 degees after top dead center is optimum for peak pressure. Thus your 10-15 degrees is a 5degree window in a possible 40 degrees or 12.5% of the likely result, that's not very precise and thus I don't expect a precise explanation.
Dunno if you follow that.
09/29/2010 12:18 PM
I follow it. And thought experiments (hey, they sure worked for Einstein) and real world experiments are the start. But then someone does the science and the math to explain why things are the way they are. That is what I want. I can't find it online and I'm asking if anyone can direct me to it.
Everything I've read on timing mentions the 10-15 range. But where did it come from? Why not 5-10 or 20-30 or some other numbers? And what are the mathematical relationships of MAP and RPM to timing? We are not lemmings and I want to know the science and math to support those numbers.
And thanks for the replies. A healthy discourse often leads to enlightenment and surprises.
09/29/2010 2:17 PM
I doubt that there is a mathematical proof for this. The ideal pressure-versus-angular-position profile is most likely unattainable by normal engine arrangements. Thus this would almost surely be an empirical result. [??]
09/29/2010 2:40 PM
We came to that 10 -15 degree range because after much trial and error testing and research that was the range that things just tended to always want to work most efficiently at.
The numbers for mathematical modeling where only assigned to help others understand happens when and where in order to get the best results to occur given specific working conditions or base line parameters of reference.
09/29/2010 2:59 PM
Trial and error...just tended to work..this is the kind of response I specifically don't want. You mention mathematical modeling; where do I find that?
09/29/2010 4:01 PM
I don't know anything about mathematical modeling of engines but I have built many engines of many different sizes, designs, and fuel types and with each the final setup and tuning work was always done by sound, touch, sight, and intuition to find what worked best in each case.
Mathematics will not tell you that one engine will prefer to run most efficiently with the cam 2 degrees advanced over the theoreticaly ideal setting while having the ignition curve start 3 degrees short of typical due to the naturaly occuring variations in the materials, machining tolerances of it components, and the particularities of the fuel batch from that day.
The theoretical or mathematical ideals are rarely the optimum working points when applied to the reality of the system as a whole. Thats why the reference to the 10 -15 degrees range is generalized and not said to be exactly 12.5004560781 degrees or something of that level of precision. Sorry but mathematics is not an all powerful and all knowing force. Its just numbers no matter how much someone may not like the reality of it.
09/29/2010 4:17 PM
Appreciate the input, but still want to see the math and science of timing. And actually if we could incorporate all the variables into the correct equations it would exactly match the real world. But for right now I'll settle for the theoretical answers to peak pressure timing, MAP and RPM relationships. Surely someone knows where it is? C'mon, guys, are we not engineers? We're supposed to have all the answers!
Good Answers: 114
09/29/2010 11:01 PM
TCM you're too modest I think you explained it here
09/30/2010 6:26 AM
Ooh you remembered!
I was so tempted to link it but then I thought I would be coming off as a jerk and you know how I hate to do that.
Well no not really I was just to lazy to track it down but thanks for once again being more motivated than me.
Hobbies - CNC - New Member
09/30/2010 12:18 AM
Heywood is the author of a $250 book that almost certainly is as theoretical as you might like. I don't have a better citation, but if a search on Heywood doesn't do it look on the forums at www.msefi.com, where his work comes up frequently.
09/30/2010 12:31 PM
Thank you, Dr. Bob. I found it on Amazon for $64 in paperback, and it looks like it has the answers I seek.
Good Answers: 60
09/29/2010 5:17 PM
The information and links below are for you to research further.
I already know what i need to know about the ignition process and it would not enhance my ability to repair or diagnose faults on the IC engine.
I have added the above note because some people wonder why i put a lot of links on here, well its so you the questioner can do some work for yourselves, I personally have no need for such advanced information as it serves no practical use.
the timing is worked out based on the time it takes for the ignited fuel/air mixture to burn, There is a finite time while the process continues before the pressure rises to force the piston down.
if the ignition point is to early then the gases will have reached peak pressure before TDC and thus energy will be lost as rotational forces contained in the flywheel turn the engine as the expanding gases try to push the piston down in the wrong direction
http://www.google.co.uk/search?q=advanced+ignition+calculations+for+internal+combustion+engines&hl=en&rls=com.microsoft:en-gb:IE-SearchBox&rlz=1I7GGLT_en&ei=S6ujTIKnFovNjAfyqfH9Ag&start=10&sa=N
http://www.zafr.com/flymanaged/ddis.htm
http://www.google.co.uk/search?q=how+igniton+timing+is+worked+out&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GGLT_en&redir_esc=&ei=K6ijTOfDPIyM4ga4spD9Ag
spark plug information
http://www.classic-car-magazine.co.uk/articles/spark_plug_colour_guide_chart.html
http://www.hotrod.com/techarticles/setting_timing_curves_tech/index.html
http://books.google.co.uk/books?id=ldkTecMGc4wC&pg=PR5&lpg=PR5&dq=basic+ignition+calculations+for+internal+combustion+engines&source=bl&ots=vK3fbwa3aD&sig=whNrFBByCGjAx1v1ayqRNn8FCO4&hl=en&ei=caqjTJahN8K4jAejg4ipAw&sa=X&oi=book_result&ct=result&resnum=1&ved=0CBUQ6AEwAA#v=onepage&q=basic%20ignition%20calculations%20for%20internal%20combustion%20engines&f=false
http://www.sciencedirect.com/science?_ob=ArticleURL&_udi=B6V3F-44J78GS-D&_user=10&_coverDate=02%2F28%2F2002&_rdoc=1&_fmt=high&_orig=search&_origin=search&_sort=d&_docanchor=&view=c&_searchStrId=1479071704&_rerunOrigin=google&_acct=C000050221&_version=1&_urlVersion=0&_userid=10&md5=992323b5465194bb26f6ff8cfd3e37f8&searchtype=a
09/29/2010 5:42 PM
Thanks, Peter, for the links, I did browse them and will study them in more detail tonight...but it looks like none of them will have what I'm looking for, namely the scientific and mathematical basis of ignition timing. As others have pointed out, we tune by the seat of our pants, or by dyno or other instrumentation if available. But I'm not interested in how to tune. I want the underpinnings, the equations, the calculations that surely must have been developed to go along with the real world observations. If not, there is a great doctoral thesis waiting to be written.
Again, I'll settle for peak pressure, and MAP and RPM relationships to timing.
Good Answers: 18
09/30/2010 4:07 AM
never mind, removed my comment. Peters right with his note as well, for me to know where the timing was calculated from originally wont make a mechanic out of me.
Always learning
09/30/2010 12:36 PM
Ah, come on, jvrj, I think you will make a great mechanic.
09/30/2010 12:09 AM
SSCpal says, "what I'm looking for, namely the scientific and mathematical basis of ignition timing".
I think you will be lucky to find what you want, and I've certainly never seen anything of the type you appear to seek.
The main reason for the above is that ignition timing is very complex at the physical analysis level and it is very much a specialist area. It is something that should be possible with a complex FEA (finite element analysis) or more likely, a CFD (computational fluid dynamics) simulation, however significant amounts of modelling data would be required. Significant computing power and expensive software is also required (think $20,000 plus for the software).
Input data will include either assumptions or specific characteristics about the fuel, air-fuel ratio's, air temperature, cylinder/piston temperatures/materials (that vary over their surfaces), engine speed, fuel charge, ignition source/location and combustion chamber shape.... at least !!!
At the practical level it is usually sufficient to use some sort of multi-parameter map for the pressure-volume curve. These parameters would typically be something like compression ratio, maybe air-fuel ratio and combustion chamber material/shape. This is the sort of approach used in a typical engine performance program. Once you have the Pressure-Volume curve for a particular set up, the power output is pretty much straightforward mathematics.
If you want to do a full simulation then you are talking CFD and chemistry, the the input costs in both dollars and data already outlined. As as an action plan I'd be looking at what CFD packages already contain, and any additional insight that might accrue through an thorough understanding of combustion chemistry.
09/30/2010 12:42 AM
Trevor, thanks for input. Yes, to accurately simulate a real world engine would take a very sophisticated model, quantification of all relevant factors and lots of time and money. But it seems to me that there must be at least theoretical scientific/mathematical explanations for the items I mentioned: optimum peak pressure timing, and the relationships of MAP and RPM to timing. Is it likely that we have been using IC engines for over a century, and nobody was curious enough to even try to work out the basic math? I find that very hard to believe.
09/30/2010 5:17 AM
Aaaarrrggghh.
That's the point...they have tried and found there are too many variables and the maths unsatisfactory so it's done empirically.
Do you expect people to write great tomes on methods found to be unsatisfactory?
Hang on..
I can hear the reply coming..
Here it is...
'Yes but...'
09/30/2010 12:29 PM
Really? Have "they" tried? Can you quote sources on this trying? Know of any record of attempts and failures? Or are you just guessing?
Hint: check Peter's latest links. I think you will find "they" have done the math. And it wasn't unsatisfactory. And check John Haywood's book, mentioned by drbobwoolery. It's definitely not a failure.
09/30/2010 12:23 AM
" But why do we specify peak pressure at 10-15 degrees ATDC?"
We don't specify it, that's what works.
Where do you suppose peak pressure should be??? I mean really, can you not apply a little common sense?
Where would you have the peak pressure occur?
09/30/2010 1:08 AM
TrevorM has stated good stuff. The idea that the scientific and mathematical analysis will be simple and not specific to individual cases is a mistake. If you look at the history of the development of the Diesel and the Otto engines and the accompanying theoretical work with the associated cycles of the same names, you will see that there is no generally agreed numbers for all internal combustion engines. If you look at racing and high performance engines you will get much different numbers. The examples given by TrevorM illustrate the range of variables needed to be included in a scientific analysis. The "simple" issue of the chemical reaction between the fuel and the air needs a precise description of all the chemical constituents and the combustion characteristics of that mixture when placed in a precisely shaped combustion chamber under stated conditions. The nature of the mixture, whether carbed or injected, is extremely important, as in the above Diesel/Otto competition. All of these things can change the desired timing characteristics. And that is just the beginning of the analysis of the chemical reaction. How about max output dragster engines, where the combustion is still taking place in the exhaust? Do you think those are set at 10-15deg?
To get a rigorous, scientific and mathematical model, you need a precise description of the engine it will describe. I suspect this also will be not what you want, but I think the people who actually use mathematical models for these things keep this information to themselves as part of their professional expertise. That is the way it used to be, anyway. If you can find an engine designer who will talk to you on your terms, go to it, and good luck.
6
United Kingdom - Member - Hearts of Oak Popular Science - Paleontology - New Member Engineering Fields - Mechanical Engineering - New Member
Good Answers: 75
09/30/2010 4:57 AM
Can you really not understand, after all of the careful explanations given here, that if there was a "unified theory" of engine design and tuning that could be applied to all engines, then
  1. It would be in use
  2. It would be taught in school
  3. We wouldn't need CFD/FEA analysis of the cylinder and combustion
There are a few other things that have not yet been mentioned, things that are nowadays of even more importance than power output and that is the composition of the gas stream leaving the engine.
All round the world, governments and regulatory authorities are imposing Air Quality standards, concentrating on reducing the particulate and NO2 loading of our air. There is a Europe-wide Air Quality standard; the California Air Resources Board (CARB) Regulations and others with which I am less familiar. These targets are cascaded down through industries and so require that new engines have very low limits on PM, CO, THC and NOx emissions. On top of this, efficiency, i.e reduced use of fossil fuel is being driven by CO2 limit legislation for new engines. There are also requirements on the continued use of older, dirtier engines, forcing the retrofitting of exhaust aftertreatment devices in order to reduce tailpipe emissions and improve air quality.
Why am I telling you this? Because what comes out of the engine's exhaust is intimately dependent on its timing set up. You can tune the engine for max torque or max power and the timing point will be different - and most likely the emissions horrendous. To tune for low PM, you'll end up with high NOx, and vice versa.
Tuning is not a simple one, two or even three parameter problem. The interactions are complex and most of them are strong interactions. As had been said here repeatedly, experimentation (trial and error) has determined the range at which the physical forces are optimised - the exact point you choose depends on a host of other inputs. If you can model this mathematically, go ahead. We will all give you the kudos you would deserve.
You're comment "c'mon guys, we're all engineers" is trite and shows a complete lack of understanding of the true nature of engineers, which perhaps best illustrated in this story, or parable if you will (I won't, but you may)
An Engineer, a Physicist and a Mathematician are at a bar arguing over the importance of excatitude. The barman's had enough, so he issues a challenge.
"You lot stand here, 3 metres from the bar. You can take moves equal to half the distance between you and the bar. First one to the bar gets this pint"
The Physicist and Mathematician look at the barman and each other and say "Can't be done. We'd never actually get to the bar"
The engineer takes 4 steps, reaches out and picks up the pint, saying "Close enough for me!"
Chaos always wins because it's better organised.
Good Answers: 114
09/30/2010 3:51 PM
When I started out as a clerk in the drafting room (although it was in London so it was a draughting room), in the structural group, they told me that a structural designer was someone who multiplied two by two on a sliderule and got three point nine nine, and then rounded it off to four for convenience.
10/05/2010 10:20 AM
"...who multiplied two by two on a sliderule and got three point nine nine, and then rounded it off to four for convenience"
Well obviously he was either using his slide rule incorrectly or it was in need of calibration.
J B
09/30/2010 10:49 PM
The story is cute and I will relate it to some of my friends. But...I wonder if an astronaut, sitting on the pad waiting to blast off, would appreciate such an attitude from the engineers who designed his rocket ship?
10/01/2010 12:21 AM
If he understands it well enough, he will appreciate it.
10/05/2010 10:42 AM
The fact is that a huge number of devices (even space ships) are designed not knowing every little detail. Engineers use theory to design, however, there comes a point where it the theory either doesn't exist or is too time consuming (read expensive) to develop or follow through on.
Where it's impractical to compute on paper, experiments are performed, tests are run. One can know how big (or small) to make something by trial and error and sometimes it's more cost efficient (in hours as well as dollars). The product may end up being the result of an evolutionary process using theory/calculation and experimentation.
If the astronauts insisted on a risk free space craft before climbing in, no footprints would exist on the moon today. It's my understanding most of the early astronauts were test pilots....the guys who jumped in aircraft to test them out...see how high they could go, how much stress they could take. Of course that doesn't mean the engineers had a "this is good enough" attitude, but they knew and lived within the constraints they had (or pushed the boundaries of those constraints such as schedule and budget).
J B
Good Answers: 74
#113
10/09/2010 9:05 PM
Well done ER
I had a parable in mind since the word go in this thread. Due to my interest in music and the maths involved I can see parallels. Please let me suggest this to the OP.
Imagine an Orchestra with all instruments tuned. All known in all aspects. The sheet music supplied to the conductor tells him all. Every speck will be played. To get back to the parallels, see him as the one who knows all and has studied all and is still learning how to get all these parts moving so to keep the well trained and sometimes spoiled customers audience happy.
I think the OP is asking to be the conductor at a stage were he can't recognize the true authority of the conductor, the incredible base knowledge needed to even think of reading a symphony score.
Understanding and defining (putting mathematical values to them) is the finer art of the representation and can be handled by the computer simulation processes mentioned by others. This is exactly the same as it is done in modern music recording controls and manipulation. Just with other hard ware attached. In both cases you would want to know your instrument.
How do I know? well I am in the same position but am willing to take NO for an answer and work on the four steps to get to the bar in time and grab that pint. I'll go and knock it back and listen to the music be it an orchestra or a well tuned engine or any other assembly of moving parts or controlled combustion's.
Even for the hard core fanatics it will never be achievable to mathematically work out why Bernstein and Karajan sound different. Why a VW sounds not like a ........ The Beatles not sound like..........Adding 15.000 psi does not sound like.....
Why would one want to try and explain with maths when the pursuit of the "real thing" and the known hardware and soft ware applications can be used to satisfy the needs, requirements or senses. OK, you can have your sensors.
Timing a clarinet at the flame sound front can be just what is needed but,... maybe not. Science? No, just good taste, Ky.
The Twain Has Met
In reply to #113
10/09/2010 10:18 PM
Actually, Heywood's book (and others) and some of Peter's links have the theory and the math that I seek. And if you like to listen to the engine, by all means do so. I enjoy the sounds myself and want to have a deeper understanding of their origin. I imagine cosmologists, like many of us, enjoy just looking at the stars at night, but they too want to know more about the music of the spheres. And that gets really into theory and math.
Good Answers: 60
09/30/2010 5:30 AM
Search Results Any Good ? It all here on the internet if you look for it
  1. Experimental Investigation of Optimal Timing of the Diesel Engine ... by B Kegl - 2006 - Cited by 21 - Related articles
    Top of Page; Introduction; Injection-Pump Timing; Experimental Section; Influence of Fuel on Engine Characteristics; Influence of Injection-Pump Timing on ...
    pubs.acs.org/doi/abs/10.1021/ef050405a - Similar
  2. [PDF] Motion planning for experimental air path control of a variable ... File Format: PDF/Adobe Acrobat - Quick View
    Motion planning for experimental air path control of a variable-valve-timing spark ignition engine. Thomas Leroya,b,Ć. , Jonathan Chauvin a, Nicolas Petit b ...
    cas.ensmp.fr/~petit/papers/cep09/main.pdf - Similar
  3. [PDF] An Experimental Result of Exhaust Emission Concentration Relative ... File Format: PDF/Adobe Acrobat - Quick View
    by MK Hassan - 2009 - Related articles
    This paper presents an experimental result of exhaust emission concentration at various injection timing for high compression engine fuelled with compressed ...
    www.eurojournals.com/ejsr_25_3_06.pdf - Similar
  4. Motion planning for experimental air path control of a variable ... by T Leroy - 2009 - Cited by 3 - Related articles
    Motion planning for experimental air path control of a variable-valve-timing spark ignition engine. Thomas Leroy a , b , Corresponding Author Contact ...
    linkinghub.elsevier.com/retrieve/pii/S0967066108001846 - Similar
  5. Aircraft Engine Detonation Prevention, Pre-Ignition, Mixture ... Aircraft Engine Cooling, Leaning and Detonation Prevention Techniques, 260954405. ... Experimental Aircraft Info .... Advancing the spark timing increases the peak cylinder pressures and the possibility of detonation, ...
    www.experimentalaircraft.info/.../aircraft-engines-detonation.php - Cached
  6. IEEE Xplore - Extremum Seeking Tuning of an Experimental HCCI ... by NJ Killingsworth - 2007 - Related articles
    26 Jul 2007 ... We use extremum seeking to tune the combustion timing controller of an experimental HCCI engine. Extremum seeking is found to be a useful ...
    ieeexplore.ieee.org/xpls/abs_all.jsp?arnumber=4282765
  7. IFAC-PapersOnLine: Experimental airpath control of a turbocharged ... Experimental airpath control of a turbocharged S.I. engine with valve timing actuators. Advances in Automotive Control, Volume # 5 | Part# 1 ...
    www.ifac-papersonline.net/Detailed/39086.html - Cached
  8. [PDF] NONLINEAR CONTROL OF HYDRAULIC CAMSHAFT ACTUATORS IN VARIABLE CAM ... File Format: PDF/Adobe Acrobat - Quick View
    by AU Genç - Cited by 11 - Related articles
    the optimisation of the cam timing over a wide range of engine operating conditions, ..... of the controllers, only experimental results are pre- sented. ...
    www-control.eng.cam.ac.uk/aug20/vct_act_control.pdf
  9. [PDF] Heptane Fueled HCCI Engine: Combustion Timing Control by Reformer ... File Format: PDF/Adobe Acrobat - Quick View
    by V HOSSEINI - Related articles
    HCCI combustion timing is determined by the temperature-time history of the ... EXPERIMENTAL SETUP. A single cylinder Waukesha CFR engine was used for the ...
    www.mece.ualberta.ca/.../CICS2007-Hosseini-Checkel-Heptane-HCCI.pdf
  10. [PDF] NUMERICAL-EXPERIMENTAL ANALYSIS OF THE TIMING SYSTEM OF AN ... File Format: PDF/Adobe Acrobat - Quick View
    Keywords: fem, multibody, engine timing system, modal analysis, camshaft vibrations, ... Numerical-experimental modal analysis of the components ...
    www.mscsoftware.com/support/library/conf/.../paper_32.PDF - Similar
  • Everything
MoreFewer
Search Options
Fewer search toolsMore search tools
1
6
7
8
9
10
Good Answers: 60
09/30/2010 5:36 AM
Good Answers: 18
09/30/2010 5:43 AM
Well done Peterg, this/you have shown that, not only does the info exist, but the OP was too lazy to look for it, or he did see it but was too clever to know what he was looking at. Doesn't look like he will be back anyway.
Always learning
Good Answers: 60
09/30/2010 5:57 AM
Good Job I am bored at the moment then
09/30/2010 8:33 AM
What's up ?
I've heard there's GA-party going on here.
I brought a few with me, only I have no clue as to what you're talking about
09/30/2010 8:59 AM
I suspect that one reason 'hardcore timing theory and science' does not exist because of the difference in combustion within the combustion chamber.
There are things like flame propagation speed, combustion chamber shape, valve orientation, and air-fuel mixing that make each engine unique.
Australia - Member -
09/30/2010 9:02 AM
My engine is way different my base line is 1.18 deg BTDC at 750 rpm and 35 deg BTDC at 10000 in a straight line.
Also my engine runs a little rough at idle fired 65 deg BTDC, I think most engines would start to spin backwards at this setting.
My engine at the moment is 86% thermally efficent and I am looking for errors to derate this figure, but my city milage is 58% better than normal.
smokingwheels
09/30/2010 9:56 AM
woodpower, english rose, jvrj, shame on you. Obfuscation and attacking the asker are the tricks of the uninformed. It's painfully obvious you haven't read the entire thread. I've repeatedly said that this is not about real world, not about how to tune a real engine, not about a super model. It's about the theoretical science and math of ignition timing.
Peterg7lyq, thank you so much for your efforts. The latest links are excellent and show that the work has been done and the math is out there. You alone have grasped my question and responded appropriately.
09/30/2010 10:11 AM
Perhaps, in the future, you could do us all a favor and just deal directly with Peter by PM. That way you wouldn't have to endure the ignorance of the rest of us.
I'm on a campaign to be nice, or I would have told you how I really feel. In your case, I believe arrogance is appropriate.
Goodbye.
09/30/2010 10:44 AM
Yes, Peter was the only one who really got it. Ignorance was never mentioned or intended, except for me; I asked the question because I was ignorant on that topic! I didn't mean to offend, but some folks veered off, and I had to restate my original question. I did appreciate the comments (well, most of them), most were really trying to help, but they were just off-target. That's human nature. Engineers are human, even if we think more clearly than the unwashed masses.
And if you want to vent, PM me and we can have a right to-do.
09/30/2010 10:49 AM
I don't need to vent. Just seems to me that you were rude to well intentioned people.
Cheers.
09/30/2010 11:13 AM
Engineers tend to think in logic and scientific facts and math; we sometimes appear rude because opinions, dearly held by most individuals (and sometimes useful), don't get the job done. I never had it in my mind to be intentionally rude. I never told anyone they were ignorant or dumb or too stupid to understand the question. But by repeatedly restating my question to get back on track I'm sure I stepped on a few toes. Such is life.
Thanks for the follow up. I am all too human and it hurts when your peers say mean things.
SSCpal
Good Answers: 60
09/30/2010 2:50 PM
WELL THAT RULES ME OUT my math is appaling i am lost wothout a calulator
09/30/2010 3:15 PM
When I was employed, I kept a slide rule and a 40-year-old TI 4-banger on my desk to remind me of how far we have come. The youngsters would gaze at the slide rule like it was from an alien civilization.
10/05/2010 6:47 PM
Talking about being rude tak a look at some of the links here
http://cr4.globalspec.com/thread/60407/Wind-Powered-Cooler
Good Answers: 141
10/04/2010 11:29 PM
I recommend strongly that you go for a doctorate in this faculty in the University of Frankfurt and also in Bayern. These places are in Germany.
In the mean time, you can work in the research centers of Mercedes Benz or (not and) BMW. There they experiment every day with all types of valves, placement configurations, fuel types and dope compositions, injection systems, combustion chambers, head chamber models, spark plugs, spark modulators, retention systems, ignition systems e.g.
Not to forget multi cylinder configurations. This list is far from complete. All these "variations" affect your proposed "narrow span".
Some engines can just reverse with changing your timing.(nota bene a used technique in some applications) Besides that, they also work on variations on your ample process parameters. 30 years ago I have seen engines there and prototypes, you can only dream of. This is called research, and the affordable results, you find in all day cars. If you want more than common knowledge, try to infiltrate in their laboratories, which requires more than a non- disclosure agreement. I don't know about other manufacturers, but I supposed it works the same there. And be glad they tell you afterwards how to run their engine.
Plenty of room here
10/05/2010 9:28 AM
Why the outburst? Have I offended you somehow, or did you not read my OP? I asked for a source for the theory, science and math re the timing of IC engines. I'm not interested in real world applications. And only two people responded appropriately with links and a book suggestion.
10/05/2010 10:16 AM
I haven't GA'd the ER answer (yet). though have read her post, and the others. Your question (as any) is fair enough, but read the respnces. Painful for you , maybe, but informative yes. I hope this does not descend into an argument of personality. You asked a question, it has been answered.
I'm not interested in real world applications - that is going to leave you open to a world of pain. Engineering is about translating the theoretical into the useful. Moving into the theory is fine, but be prepared for the knocks.
10/05/2010 10:45 AM
I read all the posts, and answered appropriately. And two people did come up with the answer. The rest wanted to offer opinions and war stories and attack me for asking. I don't understand that mentality. And I've been designing and building real world applications for 45 years.
10/05/2010 10:48 AM
theres a lot of that on here
people answering non existent questions, adding things that dont make sense just ignore them
10/05/2010 10:59 AM
Thank you. I was beginning to doubt my sanity!
Good Answers: 114
10/05/2010 10:29 AM
What good is theory, without real world applications[rwa]?
D has directed you to organizations involved with the hated RWA's
These organizations have the resources to develop & document the mathematical relationships you desire.
Organizations that have spent large sums developing RWA's are unlikely to offer up proprietary information to the public [or their competitors].
I think you are struggling with the nature of CR4 [& forums in general]
The threads have a life of their own. Berating the participants won't improve the quality of the responses.
10/05/2010 10:56 AM
How did this thread get so twisted? I asked a simple question, and people explode with nasty comments. Only two people responded with links and a book that answer my question. The rest seem to take pleasure in ranting about RWA's (which I repeatedly reminded them was not the question) or taking pot shots at me. Good grief, I expected a much higher level of discourse from engineers, and, in real life, have usually found it. I'm beginning to suspect that many of the posters are either not engineers, or just like to roam around and cause trouble.
Good Answers: 114
10/05/2010 2:27 PM
your question is far from simple
you continue to feel like you can dictate the nature of the responses
One would generally have to pay for that privilege
I think the level of discourse is directly related to your responses & the poor design of your original question.
if you really expect to have a high level discussion of ICE design parameters you would be better served on a forum dedicated to combustion engineering
In reply to #60
10/05/2010 6:31 PM
The question was simple, and two people answered it simply and correctly. The rest were off-topic or offered opinions, war stories or made nasty comments unbecoming of engineers or any decent person. I restated the question repeatedly to help people understand how, and if, to respond. If one doesn't have the answer, then one should not respond. CR4 is not a chat room.
Never asked for a discussion of anything; that is a different type of thread.
Good Answers: 60
In reply to #63
10/05/2010 6:45 PM
Good Answer Very diplomatic, I am not that curios nice to be of help
Good Answers: 114
In reply to #63
10/05/2010 9:44 PM
There's no way to distinguish a question from a discussion...
like it or not CR$ is technically oriented entertainment
you have have been here since 06, surprising that you don't have a better idea of the nature of this place.
you start a thread, it goes where it goes
take what you find useful, other people [yes there are other people learning from this thread] take different parts to be meaningful & educational.
You presume that this thread is only for your benefit...
In reply to #69
10/05/2010 10:35 PM
Garthh...this conversation will serve no useful purpose...goodbye.
10/05/2010 2:59 PM
I am curious to know which of Peter's links was/were the best at answering the OP's question.
Good Answers: 60
10/05/2010 3:31 PM
And me Cos as Usual i have posted quite a few.
But what he was after was the theoretical timing as opposed to the actual timing.
10/05/2010 6:46 PM
Peter, it looks like the first two links of your response #31 are really on target. The others may have some nuggets of good info, or will lead me to other good places; I have a lot of reading to do.
The Haywood book mentioned by drbobwoolery (#17) looks like an excellent reference work, and I have it on order.
Good Answers: 60
In reply to #65
10/05/2010 7:12 PM
Good I thought some of them looked promising, I only scanned them quickly to see if the contained what i was looking for Funnily i didn't discover what i was looking for but discovered what i though you needed.
What i was looking for shows the valve timing, ie overlap when both valves are open, the Timing cycle and when projectiles igniton should occur, which is then taken over by the Engine management unit which modifys the timing to keep the engine close to detonation ( pinking) as it monitors detonation by pizeo senders listening to the engine for the onset of of pinking noise. the noise of the engine combined with the oxygen content of the exhaust etc etc.
anyway nice one
In reply to #67
10/05/2010 9:13 PM
Detonation is another area of interest for me. I am experimenting with a programmable distributor and getting into some scary areas of high advance. Here is one aftermarket knock sensor I've been looking at. I imagine modern ECU's are more sophisticated, but I'm working with an old fashioned engine.
Good Answers: 130
In reply to #68
10/06/2010 12:00 AM
"Detonation is another area of interest for me"
If this is the case I think you need to look harder at the 'just give me the answer I want', attitude toward the answers offered.
For example; Del referred you to the geometry of a circle - which is the reason/answer for base 'timing' of peak pressure.
A bit of thought - by you - on that - in terms of a statics force diagram - answers "150", just as in a scissor lift "useful unfolding" threshold.
Add then, the inertial factors of rpm and burn rate and the "theory and science" of your question is fully answered - like why it moves toward TDC.
Or to summarize; it was answered in 1. and "poorly appreciated" along with all subsequent informative input.
So; something 'informative' for the new quest; "detonation" and "pinking" (or "knocking") are quite different things....
and it may save on the Wiki search for the answer as you want it.
Good Answers: 114
In reply to #71
10/06/2010 12:13 AM
High five :D
Good Answers: 130
In reply to #72
10/06/2010 1:09 AM
I wonder if the OT vote is from the OP or from Wiki7000?
Good Answers: 114
In reply to #74
10/06/2010 1:26 AM
OP said I 'm a dooty head & promised not to talk to me, I wonder if that extends to voting?
I never heard Wiki7000 express any views one way or the other about the subject of GA/OT
& yes Del's reply was in fact comprehensive, getting right to the heart of the issue [he should take a tin of tuna & a peck of atta boy's from petty cash]
Good Answers: 60
In reply to #71
10/06/2010 4:00 AM
Oh no they are not they are one in the same different name same thing
http://www.google.co.uk/search?q=pinking+and+detonation+in+petrol+engines&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GGLT_en&redir_esc=&ei=yyusTLOvBdC6jAfo-PHMCw
taken from above link to re inforce my point
Search Results
  1. Engine knocking - Wikipedia, the free encyclopedia ... pinging or pinking) in spark-ignition internal combustion engines occurs when ... Detonation can be prevented by any or all of the following techniques: the use ... Manganese compounds are also used to reduce knock with petrol fuel. ... Diesels actually don't suffer the exact same "knock" as gas engines since ...
    en.wikipedia.org/wiki/Engine_knocking - Cached - Similar
  2. Light and heavy vehicle technology - Google Books Result Malcolm James Nunney - 2007 - Technology & Engineering - 671 pages
    For both petrol and diesel engines the geometric shape of the combustion ... as being one of the important factors controlling pinking or detonation, ...
    books.google.co.uk/books?isbn=0750680377...
  • 23 What causes engine knock/pinging/detonation? <NOISE> 23 What causes engine knock/pinging/detonation? A: Too much advance. Check Timing. Also check VALVE timing. Too low gas octane/too high engine compression. ...
    stason.org/.../23-What-causes-engine-knock-pinging-detonation-NOISE.html - Cached - Similar
  • Knock, detonation and pinking... 8 Nov 2006 ... Inherently, small-bore engines are less prone to detonation than those .... engines and be too cheap to put good fuel in when they race. ...
    www.tyresmoke.net/forum/.../2582-knock-detonation-pinking.html - Cached
  • Pinking | Technical matters | Back Room Forum | Honest John 29 Apr 2002 ... I think its pre-ignition , that is when the petrol/air mix in the cylinder ... I think most car engines these days will automatically adjust ignition timings to ... Re: Pinking - John S. dan. Close! Yes, it's detonation ...
    www.honestjohn.co.uk/forum/post/index.htm?t=5302 - Cached - Similar
In reply to #76
10/06/2010 4:04 AM
  • So; something 'informative' for the new quest; "detonation" and "pinking" (or "knocking") are quite different things....
  • Peter is right detonation/pinking/knocking, are all the same
  • Shoptalkforums.com • View topic - Compression Ratio , Knock ... 8 posts - 3 authors - Last post: 4 Aug 2004Post subject: Compression Ratio , Knock , Detonation , pinking and . .... quality control it will have between 18-22 degrees total advance, ...
    www.shoptalkforums.com/viewtopic.php?f=3&t=75449&start... - Cached Get more discussion results
  • Knock, detonation and pinking... 8 Nov 2006 ... Inherently, small-bore engines are less prone to detonation than those ... These systems only have a limited amount of control and are designed to stop detonation in ... advance and you advance the timing to 39° and detonation occurs, ... engines and be too cheap to put good fuel in when they race. ...
  • AVGAS in Cars [Archive] - PPRuNe Forums 27 Apr 2009 ... 'Pinking' is also known as 'knocking' or detonation -- as .... I have heard that Avgas 100L was used in a classic Mini in the ... I've been running various petrol engines on it for years, still am, but NOT WITH CATS. .... They are not normally able to advance the ignition beyond the factory setting. ...
    www.pprune.org › ... › Supplementary Forums › Jet Blast - Cached - Similar
Good Answers: 130
In reply to #76
10/07/2010 7:18 AM
"Oh no they are not they are one in the same different name same thing"
What? Try punctuation - maybe that would help.
"taken from above link to re inforce my point"
'reinforce' is a word.
But perhaps you meant Whohoo!
But - still - they're not.
What you need to do is get a copy of Sir Henry's book - absorb that - then get some real engine modification understanding from 'books' - not dweebs on interweb who say things like;
"I've got this timing advance thing for cold starting"
(or what your "guest" is giving you the GA's on account of)
..... whereas the actual functional term is "retard".
Good Answers: 60
In reply to #78
10/07/2010 8:11 AM
what has that to do with the question. you constantly correct me on my typing errors i don't care i am not a typist, I don't care about the mistakes, Your wasting your time.
The only thing you may do is drive me and others of this site, That will harm the people who need answers, And not the likes of you.
Have you ever thought of teaching
So you are calling me a retard, Do you know how offensive that is to people who have learning problems.
You really need to consider why people post on here
Good Answers: 130
In reply to #79
10/07/2010 8:56 AM
I was talking about ignition timing.
You, if I recall correctly, put up the colour coding of spark plugs as "relevant"
You are again telling me I'm "wrong" - so I guess expect "offense" to be taken.
You should be caring about ALL your mistakes - if you "consider why people post on here"
"Have you ever thought of teaching"
Ok, let's look at that new tack;
"The only thing you may do is drive me and others of this site, That will harm the people who need answers, And not the likes of you."
This should be typed thus;
The only thing you may do is drive others and myself from this site. That will harm the people who need answers. And not the likes of you.
Naturally I disagree with the sentiment expressed - but expressed it is, on your behalf.
I am happy to 'give answers' - but 'giving' does not engender 'learning'.
Teaching is about learning. This guy realised that, and you need to too.
"Harm" is a multifaceted concept - or why the OP 'offended and ignored' most posters on this thread.
Now pull your wimpy little "personalizing" head in and think about that.
Register to Reply Off Topic (Score 11)
Good Answers: 60
#81
In reply to #80
10/07/2010 9:06 AM
thanks for your comments, i feel so much better now
you have now succeeded in driving me away.
have a nice life.
Good Answers: 130
#82
In reply to #81
10/07/2010 9:33 AM
You didn't read it - did you
You will get nowhere if you don't read and learn from the experience.
Good Answers: 114
#83
In reply to #79
10/07/2010 11:29 AM
I generally don't give your posts more than a cursory glance.
your method is well known
you've learned how to search, cut and paste which means you have some skill with the keyboard. there are many fine spell check programs & other aids available to help make your writing easier to understand
I generally assume your posts contain no original content what so ever
That my not be the case, but due to the sheer volume & your style of presentation, how could any one tell?
You could try some other methods to make your replies more useful.
when you have no particular knowledge of a subject, you might try offering insights into the process of formulating an effective search
Another method is to provide a short synopsis & a link or other attribution of the source material which is the proper protocol to avoid concerns regarding plagiarism
Good Answers: 60
#84
In reply to #83
10/07/2010 12:02 PM
your comments noted.
I thought the idea on here is to help the OP with their questions, Now if that means getting links that relate to the question so that the OP can see what is available on the net then thats not a bad thing is it.
Some of my comments are from experience, But whats the point of typing a thousand words when there is information already on the net ? as for plagiarism surely that only applies if one claims the work as one`s own ? this i have never done.
My sole purpose is to respond with as much information relating to the subject the OP requests, Whats wrong with that ?
By the way the spell checker does not correct my grammar
as for usefulness i believe i was one of only 2 people on this thread who gave the correct answer
Good Answers: 114
#86
In reply to #84
10/07/2010 1:02 PM
I'm sure most everyone can type in a search.
If you don't help OP's improve their information gathering techniques, you will continue being a research assistant for those that are too lazy or dim to do their own searches, feel free.
When you paste huge blocks of text with out clearly citing your source it is plagiarism
If you are unable to provide any sort of commentary [add value] what's the point of more than link
or http://www.google.com/search?sourceid=chrome&client=ubuntu&channel=cs&ie=UTF-8&q=plageriarsm#hl=en&sa=X&ei=1PitTMP2OY6asAPxrOzNDA&ved=0CCoQBSgA&q=plagiarism&spell=1&fp=5a996d56de453056
You take pride in the fact that the OP found some of the blizzard of info you provided useful
you had no idea which part had value, do you actually study the information you are posting?
Good Answers: 60
#87
In reply to #86
10/07/2010 2:02 PM
"you had no idea which part had value, do you actually study the information you are posting?"
Now this statement is very puzzling ? If i had no idea what part was of value, How do you suppose i found the link in the first place?
Its not as if the links are random ie question from OP .Timing Theory and Science
and i provide a link like this
http://www.google.co.uk/search?q=how+to+grow+cactus&sourceid=ie7&rls=com.microsoft:en-gb:IE-SearchBox&ie=&oe=&rlz=1I7GGLT_en&redir_esc=&ei=eAauTKW3LMWOjAe8kpVH
or http://www.5min.com/Video/How-to-Grow-Cactus-18630283
Plainly has no value, But as all the links i provided on this occasion had Value, it would be hard to pinpoint which exact link was the one he required.
Also i use this simple method i Get all the relevant links in one place HERE, then i go through them in more detail to find what i consider is the most like what i think the OP needs, But and the beauty of posting them all here is if i am wrong in selecting what i think is the most relevant the OP may find one of the links i haven't selected as the one the OP needs.
Is the world going to explode if i enter to many links ?
or is it just you like being the top DOG, i cannot understand what your problem is.
So instead of providing no information which is what you seem to be advocating,
I post all the links relating to the information i can find.
Now as this is not using up vast resources and turning England into more of a waste land than it is now, I can not see what you dislike about it.
Other than i CAN find the information and you plainly cannot
"When you paste huge blocks of text with out clearly citing your source it is plagiarism"
How do you make that out if i don't claim it as my own work ?
the following disagrees with you ( not me )
What is plagiarism?
At UNC, plagiarism is defined as
"the deliberate or reckless representation of another's words, thoughts, or ideas as one's own without attribution in connection with submission of academic work, whether graded or otherwise." (Instrument of Student Judicial Governance, Section II.B.1.). Because it is considered a form of cheating, the Office of the Dean of Students can punish students who plagiarize with course failure and suspension. Full information can be found on the UNC Honor System page.
taken from
http://www.unc.edu/depts/wcweb/handouts/plagiarism.html
Now you will also see at the bottom of the page a disclaimer about my posts and on my avatar there you will also find a disclaimer
Ive even started putting note on the page as well
also take from http://www.unc.edu/depts/wcweb/handouts/plagiarism.html
How can I tell whether I've plagiarized?
If you've followed the above guidelines but still aren't sure whether you've plagiarized, you can double-check your work using the checklist below.
You need to cite your source, even if:
  1. you put all direct quotes in quotation marks.
  2. you changed the words used by the author into synonyms.
  3. you completely paraphrased the ideas to which you referred.
  4. your sentence is mostly made up of your own thoughts, but contains a reference to the author's ideas.
  5. you mention the author's name in the sentence
So as i read it i Havent plagiarized Have i or am i missing somthing ?
Good Answers: 114
#88
In reply to #87
10/08/2010 12:54 AM
this one should cover just about any situation link
From the FAQ's
Can I post copywritten material? If you own the copyright, then post away. If you're not the owner, then limited presentation of material is permissible via the "Fair Use" Doctrine. A reasonable rule-of-thumb is that copying three paragraphs from a normal-length news article or editorial (approximately 300 words) is acceptable as long as attribution is provided; however, this is not a hard and fast rule. If there is a question, simply don't do it. If you do not know the copyright status of a given block of text, assume it is owned by someone else.
you regularly cut & paste several screens of text on a single post
#89
In reply to #88
10/08/2010 4:24 AM
SSCpal (22) [OP responses]
peterg7lyq (20) [clear winner in screen inches @ 8.89 feet]
Garthh (9) [8 on; 'which of the 106" was the useful half inch?]
34point5 (5) [nasty Russian ignoring "you're wrong" & "emotive cards" insults/squeaks]
Others covered by line 2 in #81
Tornado (4)
Del the cat (3) lynlynch (3), tcmtech (3)
Coldspot (2), JBTardis (2), jvrj (2)
drbobwoolery (1), dvmdsc (1), English Rose (1), Kris (1), passingtongreen (1), smokingwheels (1), TrevorM (1), woodpower (1), Yuval (1)
Oh, I feel a link or two coming on ....
In reply to #89
10/08/2010 5:03 AM
I may be biased, but I think my post was the most helpful/insightful/pre-cognitive/peace-brokering one here.
Having been so nice as to OT it myself, some complete and utter bastard added another OT vote. This thread is pants !
In reply to #90
10/08/2010 6:14 AM
Kris, you're a nice fella: Could you explain to me, in very simple terms, what is this thread about.
Maybe I'm in the first (or last) stages of dementia, but I really can't figure out what is it about
Good Answers: 60
#92
In reply to #91
10/08/2010 9:01 AM
the op wanted to know information on theorectical timing of ice engines.
most peopl told him there was no such thing, or it didnt matter. but they did not answer the question.
i and some one else gave the op the answer he wanted. the end
some of the other posters thena attacked me for giving to much information ????
the others in question then attacked my grammar, spelling and typing, none of which had anything to do with the original question.
the end
Is that clear enough ?
Good Answers: 114
#93
In reply to #91
10/08/2010 11:14 AM
The original question is a fairly simple:
what is the mathematical formula used to determine the ideal ignition timing of an internal combustion engine
there were certain members who questioned the need for such a formula & outlined various methods of determining the ideal timing to optimize certain characteristics, that didn't involve any math what so ever
this upset the OP who then felt the need berate or other wise express his displeasure at the normal modes of operation [for which there aren't any mathematical formulas either]of this place
on this end of the thread there has been some discussion of the relative merits of the methods employed by a certain member
this member has taken exception to the observation that quantity is not superior to quality & much like any class in an institution of higher learning there is extra credit when one can demonstrate a mastery of the subject beyond the ability to simply regurgitate massive quantities of other peoples work.
Though this member continues to assert the superiority of his post(s), due to OP's feedback on the subject.
Del's post demonstrates an understanding of the forces governing the problem, while Tornado outlines a path to developing the formula in question. These are clearly the most relevant posts, unless the question is how do I do a search?
in the case of search prowess there would also be some disagreement as to the usefulness of the scatter shot method being employed by the member claiming the supremacy of his contribution...
Good Answers: 60
#94
In reply to #93
10/08/2010 1:03 PM
since i didn't know exactly what the OP required giving him a wide selection of appropriate links seemed like a good idea.
and it worked the OP is happy with one of my links. JOB SORTED
Q Was he happy with any of your links or answers ??
Q where on the OP `s question did it specify that all answers had to be TYPED,SPELT, AND GRAMATICALY CORRECT ?
ORIGNINAL QUESTION
OP`S ANSWER TO ONE OF MY POSTINGS
JOB DONE
Good Answers: 114
#95
In reply to #94
10/08/2010 1:40 PM
Just Like the OP you assume that he is the only one gaining any knowledge from this thread.
JOB SORTED
Good Answers: 60
#96
In reply to #95
10/08/2010 1:56 PM
do you mean i should try to answer the unasked question of the persons reading these threads ??
i answered the OP`s question what more is there to do ??
Good Answers: 60
#99
In reply to #95
10/08/2010 2:50 PM
But he/she the OP was the only one asking the question to be answered.
So what your really saying is this site if for the few long time users for there own private use.
And we are as newcomers to YOUR site are not allowed to use it as a question and answer service.
Now you see thats where i was going wrong, I assumed that when someone asked a question, that the idea was to give an answer and not to drift off with unconnected gibberish relating to something Else completely different.
Sorry my mistake.
So why did you set up this site ? was a form of old timers social club ?
Good Answers: 114
#100
In reply to #99
10/08/2010 7:19 PM
I'm actually saying quite the opposite. I advocate the open exchange of ideas
threads have a life of their own. the OP is actually an old timer, by virtue of seniority having joined in 06, you on the other hand have many more posts in your tenure, even rhkramer meets my minimum standard a registered member who has posted.
within many threads there are other discussions on & off topic,
you blundered into Vlad & proceeded to make certain observations, which I found to be in line with your usual mode of reasoning. This prompted me to explore your methods & comment a bit.
I'm not suggesting that we drift off into unconnected gibberish. Your method is about one step above that, hurl a bunch of links & text, hoping something will stick. that some find worth in these types of posts does not increase the actual value.
In reply to #100
10/08/2010 9:03 PM
As the OP, I chose to ask a question, not start a discussion. Those are the two options CR4 offers. The fact that many ignore the distinction does make it difficult for those who only seek an answer. One fellow offered a reference work which I have ordered. And Peter offered many links, including two I have found very good, and the rest I will be reading as time permits. I'd sooner have a lot of links than opinions, war stories and way-off-topic comments, and, worst of all, snarky posts that just are not what I would expect of engineers. I never intended to offend anyone, but felt I needed to restate my question to get us back on track. If threads do indeed take on a life of their own, then maybe we need to rethink how CR4 operates; the majority of the posts on this thread were of no use to anyone except maybe the poster who wanted to opine,vent or hurt others for fun.
Good Answers: 114
#102
In reply to #101
10/08/2010 10:46 PM
As I said a few posts back there is no distinction between a question & a discussion
the only purpose the checkbox serves is to cause the original poster to waste a mouse click
when I look at the top of the page I see
The Engineer's Place for News and Discussion
Home>Automotive>Automotive>Timing Theory and Science
nary a mention of questions or any indication of your ownership of the thread
all members are welcome to unsubscribe at any time, should they lose interest or for any reason what so ever
what a member finds interesting or useful in no way dictates what others may find useful or interesting.
as to the operation & nature of CR4, it is what it is....
just like most things on the internet, participation is completely voluntary
should you feel as if you can do a better job of running a forum, you can build your own, maybe you could use the wiki for advanced "T" bucket building
34point5 (12); Anonymous Poster (7); Coldspot (2); drbobwoolery (2); dvmdsc (4); English Rose (1); Garthh (21); JBTardis (2); jj65779 (1); jvrj (3); Kris (5); ky (3); lyn (3); passingtongreen (1); peterg7lyq (26); pinevi (1); smokingwheels (1); SSCpal (40); tcmtech (3); Tornado (5); TrevorM (1); user-deleted-1105 (3); woodpower (1); Yuval (5)
You might be interested in: Timing Screws, English Pitch Timing Belts
