Previous in Forum: Required Pipe   Next in Forum: Hydrostatic Test
11 comments
How To Fix Rubber Tube Together For Sound Absorption
10/05/2010 10:43 AM
Comparing with rubber pad, I found row of rubber tube is more effective in reducing noise for impact load
The difficulty is how to fix rubber tubes together to a plate shape firmly by handmade method.
Anyone knows?
Thanks
Re: How To Fix Rubber Tube Together For Sound Absorption
10/05/2010 11:04 AM
(usual disclaimer)
10/05/2010 11:14 AM
I don't think it works for repeated punching (can still keep together).
Also, tube itself mostly is a little bit curve and difficult to set.
Any better idea?
10/05/2010 11:53 AM
You can get special EPDM adhesive from suppliers of EPDM roofing materials. That should do it.
Alternatively tie it to a cloth backing and let it wriggle a little...as the old joke goes
"Excuse me miss, do you keep stationary?"
10/05/2010 1:33 PM
superglue
10/05/2010 1:33 PM
How about lacing it together by passing string through the insides of the tubes and around the ends?
Good Answers: 181
10/05/2010 4:50 PM
The good old engineers stand by "lash it together with a bit of string"
10/05/2010 5:26 PM
The other choice was duct tape!
10/05/2010 6:02 PM
Combined method may be OK
Duct tape lace+superglue+elastic string through inside
Good Answers: 213
10/05/2010 11:50 PM
Duct tape and bailing wire. If it is good enough for NASA, it is good enough for me...
Good Answers: 181
10/06/2010 4:59 AM
Buy a rubber door mat (the type with knobbly bits) and cut a section out of that.
10/06/2010 8:02 AM
Lets try hi-tek! use tiewraps
Register to Reply 11 comments
Anonymous Poster (1); cwarner7_11 (1); DGCYS (1); PWSlack (1); TonyS (2); Tornado (2); user-deleted-1105 (1); youngken (2)
