Previous in Forum: Cooling and Humidity Control   Next in Forum: Purpose of WPS
Reinforcement Pad
10/07/2010 1:39 PM
Hi, run pipe od=2900mm,thk=19mm and branch pipe od=219mm,thk=8mm
pressure operation=22 bar TEMP. OPERATION=225 degree celcius
type of pipe=API5L gr.B SEAMLESS ANGLE=90 degree
I WANT TO KNOW AM I NEED TO use reinforcement pad or no? if need dimension of pad?
Good Answers: 38
Re: reinforcement pad
10/07/2010 3:08 PM
gapeee...
Your question makes no sense.....IMHO, you should stand way back during startup
Following commonly used piping codes and assuming carbon steel materials, a run pipe of 2900 mm with a 19 mm wall thickness will not sustain 22 bar internal pressure.
You will need a wall thickness closer to ~100 mm
Furthermore, your D/t will be: 2900/19 or ~152. And since this ratio is > 100, the piping code rules do not apply and localized buckling effects must be considered.
(See "Tubular Steel Structures, Theory and Design"; Troitsky - Linclon Arc Welding Books)
Seamless pipe ?/?? at 2900 mm diameter......Where is your typo ?
10/08/2010 1:16 PM
Hi and th's for your answer,you are true ,my aim of header is not pipe,it's a drum with this od and 19 mm thickness,and the branches is a nozzle connected to the drum,
it's a steam line 22 bar and 220 degree ce...
th's if you help me?
good wishes
Re: Reinforcement Pad
10/08/2010 7:30 PM
I think the drum has the same problem as the pipe: too thin for the pressure.
The ASME Boiler and Pressure Vessel Code has a section on nozzle reinforcement. It includes a cross-sectional drawing that shows 5 areas that must add up to the necessary part of the shell that has been removed. Unfortunately, I don't have a copy (just winging it from memory of pressure vessel days of yore).
Register to Reply 3 comments
gapee (1); MJCronin (1); Tornado (1)
