Previous in Forum: Sodium Vapor Lamp vs Mercury Vapour Lamp   Next in Forum: Setting of Over Load Relay in Star Delta Starter
Wind Turbine Grid Connection
10/11/2010 5:48 AM
1 - off 15 kW wind turbine 120 meters from the 3 - off 6kW inverters ( cable 16mm ) distance between inverters and the transformer on the pole is 35meters, existing cable 25mm is this cable ok
Good Answers: 181
Re: wind turbine grid connection
10/11/2010 6:48 AM
Turbine voltage. Inverters 1Ph, 3Ph, voltage, give us a clue.
Rule 75
10/11/2010 8:40 AM
Proposed installation of a 15kW / 300 V single phase wind turbine.
Turbine located 130 meters from Grid Connect Controller, Inverters ( 3-off WB 6000 ) 240V etc, cable size 16mm
Distance from Inverters to pole mounted 15kVA transformer is 35 meters,
existing cable 25mm
Hobbies - Fishing -
Re: Wind Turbine Grid Connection
10/12/2010 12:49 AM
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.” -Mark Twain
Hobbies - Musician - New Member Hobbies - DIY Welding - New Member Hobbies - Fishing - New Member Engineering Fields - Acoustical Engineering - New Member Engineering Fields - Electrical Engineering - New Member United Kingdom - Member - New Member
10/12/2010 8:21 AM
Hi there, having looked at your specification and can see the WB 6000a grid connected inverter has a nominal operating voltage of 275 Volts dc to operate, as this unit has an input range of 246 to 600 volts.
This would not allow your system to be as efficient as it could be. You may require more inverters of a lower operating voltage to match you turbines 300 volt maximum output.
If you check these details are correct i will endeavour to do your calcs using British Standard Calculations, ie volt drops designed for calculating in metres and not feet.
Good Health Dub
If you do not have you own philosophy you cannot amend it.
10/13/2010 3:48 AM
British Standard 7671 is OK.
Dub (1); lighthasmass (1); PWSlack (1); tmac (1); TonyS (1)
