Previous in Forum: Wind Turbine Grid Connection   Next in Forum: Charger Circuit for 12v Battery Lead Acid
8 comments
Setting of Over Load Relay in Star Delta Starter
10/11/2010 6:21 AM
What should be ideal setting of Overload Relay in Star Delta Starter.
Suppose Motor is 63 KW,415V,0.8PF
FLC(Line) = (63x1000)/(1.73x415x0.8) = 110 Amp
OL Relay should be set betwenn 103 Amp to 113 Amp
OR
FLC (Phase) =110/1.73 = 63.5 Amp ( 58 % of FLC (line) = .58x110=63.5 Amp)
OL Relay should be set near 64 Amp.
Good Answers: 181
Re: Confusion in setting of Over Load Relay in Star Delta Starter
10/11/2010 6:40 AM
Depending on where the O/L's are fitted, the incoming line or one out going line.
105A or 61A
10/11/2010 7:04 AM
Before Main Contactors. (Supplay>OL Relay>MAin Contactor)
India - Member - New Member
Good Answers: 164
10/11/2010 7:26 AM
Generally in ΥΔ starters, the relay is within the delta, so it is set to the phase current, in your case 64A. Not always though, you need to check your connections.
10/11/2010 7:55 AM
Thanks
India - Member - design engineer Engineering Fields - Electrical Engineering - New Member United Arab Emirates - Member - New Member
Re: Setting of Over Load Relay in Star Delta Starter
10/12/2010 8:32 AM
Go with 64
The Star/Delta starter is manufactured from three contactors, a timer and a thermal overload. The contactors are smaller than the single contactor used in a Direct On Line starter as they are controlling winding currents only. The currents through the winding are 1/root 3 (58%) of the current in the line. In your case 64A.....
There are two contactors that are close during run, often referred to as the main contactor and the delta contactor. These are AC3 rated at 58% of the current rating of the motor. The third contactor is the star contactor and that only carries star current while the motor is connected in star. The current in star is 1/root 3 (58%) of the current in delta, so this contactor can be AC3 rated at one third of the motor rating.
shamith gambhir, electrical engineer
10/13/2010 3:46 AM
Set it to the same value as the full load current stated on the maker's name plate attached to it, particularly if it is still under manufacturer's warranty.
05/08/2013 10:19 AM
How to change the direction of rotation in a star delta starter?
Reply Off Topic (Score 6)
02/21/2024 3:32 AM
Swap any two of the three incoming phase connections.
Anonymous Poster (2); electricity_123 (1); kvsridhar (1); PWSlack (2); SHAMITHGAMBHIR1 (1); TonyS (1)
