Previous in Forum: Setting of Over Load Relay in Star Delta Starter   Next in Forum: Transformer and Alternator Ratings
8 comments
Charger Circuit for 12v Battery Lead Acid
10/11/2010 8:18 AM
hi all, could u all tell me, what the circuit that i must choose to charge the battery, and when the battery is fully charge, (lets say 12V), it will cut off automatically, i hve no idea about that....
Re: Charger Circuit for 12v Battery Lead Acid
10/11/2010 9:13 AM
To charge a battery normally we should take a potential equal to the battery (In your case 12V) and 1A as ideal current.(40AH/20=2A). Inorder to step down the standard AC supply use single phase stepdown transformer, bridge rectifier circuit (a four diode arrangement with standard capacity) and a series resistance/variac to limit the current. You have to find out values of each component for your purpose.
Good Answers: 181
10/12/2010 12:34 AM
Charging voltage is 13.8.
It's quicker, easier and cheaper to go to your local car accessory shop and buy one.
India - Member - New Member Engineering Fields - Electrical Engineering - New Member
10/12/2010 3:27 AM
indicator for 12V charger.
10/12/2010 3:32 AM
the charger circuit.
10/12/2010 3:57 AM
We can remove that parallel voltage level indicator IC1(A,B,C,D),resistors,LED,zenor diode to make it simple.As they are parallel they don't change anything.
all we need is a transformer(1ph,230/12V,2A ),IN5402 diodes-4, 2200µ-25V capacitor to filter the harmonics.
see standard fuse wire for 2.5A
around RS.120 with voltage level indicator in the circuit.
all the best.
10/12/2010 9:03 AM
thanks for the circuit, but it is cut off when it reach the fully charge???
10/12/2010 9:55 AM
To cut off observe the indicator diagram i have given.you can see a diode with transitor and a relay on top right of circuit. When the battery is fully charged the transistor comes under saturation via LED to activate the relay from NC to NO hence cutting the 1 phase supply to charging circuit. Cheers
02/21/2024 3:33 AM
Battery chargers are widely available commercially. There is no need to reinvent the proverbial wheel; just buy one.
Anonymous Poster (2); hithuanand (4); PWSlack (1); TonyS (1)
