Previous in Forum: FUEL GAS CONSUMPTION FOR GAS TURBINE   Next in Forum: Radiator Throws Water Out.
LPG Pipe line - Ice Formation
10/13/2010 4:10 AM
we hv 2 bullets in our gas plant, through which gas goes to different kilns.
so one night we observed that there is ice formation on gas trains gas pipe line,
and flow got reduced only in one kiln.
Please tell me why it has happened ?
taking no risk is the biggest risk in life
Pathfinder Tags: LPG
Good Answers: 150
Re: LPG Pipe line - Ice Formation
10/13/2010 3:42 PM
Moisture, combined with the right temperature and pressure can result in the formation of Methane Hydrates. You don't say what the outside temp was, or what pressure the system was operating at. You could also have an issue with self-refrigeration if there is a large enough pressure drop. The moisture could be coming from the combustion products finding their way backwards in the system, or could have been entrained in the gas supply.
Who is John Galt?
09/18/2011 5:15 PM
it is like this : gas is coming in line at 1.4 bar and then comes our gas train in gas train pressure of gas is reduces to 150 mbar and from that gas goes to burners of kiln.
the outside temprature is 21 deg. C.
and ice formation is on outer surface of pipe nearby gas train
Good Answers: 150
09/19/2011 9:02 AM
you have a self-refrigeration problem. pressure is dropping too fast (probably a small orifice causing the pressure drop.) you have a partial obstruction in the line causing a pressure drop.
Who is John Galt?
Register to Reply 3 comments
