Dear Sir,
What is the maximum span for DN600 water filled G.I pipe ? If the outside diameter & wall thickness of the pipe is 609.6mm & 7.9mm respectively.
What is the maximum span for DN450 water filled carbon steel pipe ? If the outside diameter & wall thickness of the pipe is 457.2mm & 7.9mm respectively.
Please let me know what is the standard that is used ?
What is the maximum allowable deflection ?
Thanks.
