Previous in Forum: Maximum Span for DN600 G.I Pipe and DN450 Carbon Steel Pipe   Next in Forum: Curb Angle Design for API+650 tanks
Boiler Tubes - Allowable Deflection.
10/13/2010 5:54 AM
Hello All,
We have a recently manufactured 5 ton per hour, 10 bar, diesel fired steam boiler that has just been installed. The boiler was manufactured to EN 12953 specifications. The third party inspector has stated that some of the tubes are deflecting to degree that requires them to be replaced - this deflection being about half the tube diameter over a length of 3.5 m (just over 11 feet). The tube ends are expanded and welded. The manufacturer has responded that the code is silent concerning the allowable tolerance on tube deflection, and some of the background research I've done has not shed any light on this either.
If anyone has experience in this regard, or can point me to a code or specification that deals with this, I'd appreciate any advice.
Good Answers: 19
Re: Boiler Tubes - Allowable Deflection.
10/13/2010 11:33 PM
To catch a thief you must send a thief, as the saying goes....
Pay another 3rd party Inspector a fees to help you out as a Consultant.
Good Answers: 181
10/14/2010 3:41 AM
Surely the boiler manufacturer can assist you in this. They're reputation must be on the line if the boiler subsequently fails an inspection based on unsubstantiated grounds.
Register to Reply 2 comments
