Previous in Forum: Boiler Tubes - Allowable Deflection.   Next in Forum: Increasing Fire System Header Pressure
Curb Angle Design for API+650 tanks
10/13/2010 7:17 AM
Hi All,
Can anybody knows abot curb angle design in api-650 tanks
Re: Curb Angle Design for API+650 tanks
10/24/2010 6:49 AM
Ref to API 650 2010 edition : Sec: 5.1.5.9 Roof and Top-Angle Joints :
Table gives you the minimum TA angle sizes, just select the closest size for your requirement. Then go and refer to section: 5.9.6 : Table 5-20a—(SI) Section Moduli (cm3) of Stiffening-Ring Sections on Tank Shells. You can also calculate the required section modulus for design wind speeds to rrive at the size for the Top Angle.
